What is a good size tire to mount to a 15 x 10 rim...
Discussion in 'The Hokey Ass Message Board' started by Zumo, Jun 7, 2006.
  1. Zumo
    Zumo
    ....beside the obvious slick? A street tire that I can have the black wall out and it look good and not stupid. This would be for the rear of the vehicle.
    Any pics?
  2. What kind of car?
    Here's a pic of a BF Goodrich 285/70R-15 on a 10 x 15" wheel.
  3. Zumo
    Zumo
  4. MickeyB
    MickeyB
    from Arvada, CO
    I was thinking 295/50/15...a little low profile, but not bad. I know BFG makes this size. I see them used once and a while on e-pay.
  5. Slag Kustom
    Slag Kustom
    i used 325 50 15 on a 10 inch rim still looks alittle short at 28" tall
  6. Nik
    Nik
    Zumo, I'd go with the BFG in 295/50. I had a set under my 71 Chevelle and it looked nice and wide from the back. 295 is 11.6 inches wide, so I guess a 305 would be a foot across? I'm not sure how much wider than that you can go if you're sticking it under your truck, the largest I ever personally used was a 275.
    Nik
  7. muffman58
    muffman58
    285/70/15 BFGs here too! 15x10 rims. Comes to 30'' tall & 9'' footprint with a 12'' width from bulge to bulge. Pretty big tire! I think there getting kind of hard to find now from what I`ve heard.
  8. monsterflake
    monsterflake
    the original "Sport Truck T/A" was (and marked as) a 31x10.50/15, which was replaced by the 285/70/15. a great tire, nice and tall, fit inside the wheel openings better than the uber-wide (and shorter) 50 series tires. they should be readily available, but might not be stocked everywhere. check summit or the tirerack...
  9. brandon
    brandon
    the 285's work nice.....i also ran a pair of 28x12.50 et streets.....but would have liked a 30 tall instead .....occassionally you can run across some old 315 70 15's.....but they are pretty rare anymore......brandon
  10. Zumo
    Zumo
    I was thinking the same or close to it. I actually had 305 50 15s on the rear on my 69 LeMans, same family as yout chevell and they looked huge. The rim was a 15 x 8 so I know the 10 would still be ok.
