Customs What is a reasonable compressor for a decent garage paint job?
Discussion in 'The Hokey Ass Message Board' started by airbrushguy, Mar 4, 2023.
  1. This is what I have and it will paint anything you want. The CFM is key.
    HP Ratings are usually total ********. Just like in tread mills the manufacturers use the more impressive PEAK #, but in reality peak HP only lasts momentarily on startup. ACTUAL HP is the number you should be concerned with.
  2. gimpyshotrods
    gimpyshotrods
    Just be mindful of what the electrical circuits on your property can support.
    Inrush current is a thing, so the load Amp max is less that what it will draw on startup.
    Smaller home compressors often do not have an unloader valve like larger ones, or commercial units.
    A compressor without one has to start against tank pressure, and that can create a substantial Amp spike.
  3. airbrushguy
    airbrushguy
    from NJ
    Found a used 220v 80 gallon, 5 running hp Kobalt…16 cam at 90psi and 17.3 at 40psi
    155 max psi…used
    How does that sound?
    Any tips on what to look for?
    Thanks for all your help
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    In many years of being around many different types of air compressors, I've never seen one without an unloader valve , some are an in tank combo valves , some are internal regulator combo valves & some are centrifugal . but they're always there IME.
  5. 1952henry
    1952henry
    Yep, even smaller roll around single stage compressors have an unloader, part of pressure regulator.
