What is behind this generator?
Discussion in 'The Hokey Ass Message Board' started by 60rftc, Feb 11, 2014.
  1. 60rftc
    60rftc
    from LBC
    I am going to be buying a pile of parts for my Olds engine and the seller sends this picture of a generator, it has some sort of pump with a reservoir connected to it. Likely from a mid 50's Olds but the seller isn't sure. I've never seen one before, but maybe it's a common part from the 50's. Can you guys help me out?
    Thanks
    J
  2. Power steering pump
  3. battersea boys
    battersea boys
    from surrey
    what he said looks like a chrysler product?...
  4. 60rftc
    60rftc
    from LBC
    Wow, thanks. I thought it might be but my 55 Buick had a p.s. pump with its own bracket and pulley so I wasn't sure.
  5. 60rftc
    60rftc
    from LBC
    Chrysler? It could be since I've noticed some non-Olds stuff in the pile.
  6. The pistons have valve reliefs sort of opposite but not quite.......they appear to be Poly pistons, the lifters also appear to be Poly, the generator is similar to mid 50's mopar, the alternator is early 60's mopar.........dunno about any Olds bits.......andyd
  7. txturbo
    txturbo
    Mid 50s GM Stuff had the power steering pump on the back of the generator like that.
  8. Frankie47
    Frankie47
    from omaha ne.
    Mopar generators were Delco also.......
    Edit....Autolite not Delco Remy...
  9. Hnstray
    Hnstray
    from Quincy, IL
    Maybe some were.....don't recall seeing any. All I remember seeing were Autolite....
  10. 4ever18
    4ever18
    56 & 57 Chevys also used a Delco p/s pump which was driven directly from the back of the generator, via a splined shaft protruding from the back of the generator.
  11. Frankie47
    Frankie47
    from omaha ne.
    You are right..Brain not functioning...Honey! Bring more Coffee!
  12. tommy
    tommy
    Mish mash of parts. Mopar alternator Chevrolet starter...generator is not a GM unit...
  13. saltracer219
    saltracer219
    the generator looks to be Autolite-Prestolite, it should have a tag. It is not Delco. The oil pumps are early Olds.
  14. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Generator/pump looks just like the one that was hanging on my '52 331 hemi.
  15. Ole don
    Ole don
    The pump itself is Eaton, same as on a Ford product of that era but with a different front casting.
  16. pammiesuesguy
    pammiesuesguy
    It's a 1956 and 1957 Chrysler power steering unit. Aftermarket part number is a 9115 for the generator. Facel Vega with the Chrysler engines use the generator for their tach drive but two ears are removed for that application.
    Rich (generator rebuilder since 1960)
  17. 60rftc
    60rftc
    from LBC
    Thanks again guys. I just wanted to ID the generator and pump, should've cropped the picture better. So much knowledge here.
  18. Roger Walling
    Roger Walling
    The generator is not smoking so it is not a Lucas.
  19. Tommy posted a GM set up - they have a smaller pump - much like some of the later single units...
    going with it being Mopar.....and like most have said -it hopefully will still have the tag with the part # on it.....
  20. mickeyc
    mickeyc
    I think if you look at the 56-354 Hemi in my albums you can see that gen. mounted on the motor without the pump, however the drive connection is visible.
  21. BISHOP
    BISHOP
    I am amazed at how smart some of you are. I didnt know what any of those parts were from.
  22. Stretchmobile
    Stretchmobile
    from So Cal
    Cadillac's had them also.
