What is it? found inside Flathead
Discussion in 'The Hokey Ass Message Board' started by JF, Oct 5, 2009.
  1. TooMany2count
    TooMany2count
    from Cahokia,IL
    This kinda bottom????
    Looks like whatever that thing is will fit :rolleyes: ....Joe
  2. F&J
    F&J
    Compare the thread pitch to a 1/4-20 bolt. I am betting the other guys are correct in that is "was" a piece of threaded rod for an aircleaner. and I can see how many miles of running could produce the uniform wear by rubbing the valve.
    Smokey Unick was known for carving out intake/exaust runners by strange means, to get a natural look. :)...i'd like to see the port it came out of
  3. Royalshifter
    Royalshifter
    Moderator
  4. CJ Steak
    CJ Steak
    from Texas
    I'm sure that pic was hilarious... but i'm just getting the dreaded red X of unfunnyness.
  5. It is a leavitrite.
  6. Ace Brown
    Ace Brown
    from OH
    hilarious Bruce. :D
  7. JF
    JF
    from Utah
    Well you guys know your stuff! it's a "****fer" :p hahaha jk
    I really can't figure it out either, I'll check the threads on it later tonight and inspect some similar air cleaner bolts for a comparison.
    After looking at the intake runner that it was sitting in again I don't see how it could have been in there bouncing around for any period of time?? maybe if one end even possibly could have been shaped that way I don't know how the other end of it could have been, it's too long to flip around in there from end to end. hmmm
  8. Chevy Gasser
    Chevy Gasser
    I think John Walker nailed this one, er I mean correctly identified it.
  9. fleetside66
    fleetside66
    Uncle Jack ain't so crazy...he's right..a cuticle tool & probably lost exactly like he said.
  10. CJ Steak
    CJ Steak
    from Texas
    I don't see how a blade could be attached... it looks like both sides are perfectly rounded.
    If there was some marking, indentation, or attachment point on this thing, it would really make it a lot easier to identify...
  11. OoltewahSpeedShop
    OoltewahSpeedShop
    There you go... Definately threaded in the middle.
  12. Babyearl
    Babyearl
    Took the words right out of my mouth,,:(
    I believe John may have seen something like this before,, I know I have:D
  13. Model A Mark
    Model A Mark
    from dallas
    hey crazydaddyo
    i read your first post this afternoon at work, omg i allmost fell out, hahah
    whered it go ??
    funny **** man.
    youd haft to be mighty balzy to do that **** to your best friend..
  14. temper_mental
    temper_mental
    from Texas
    Double ended **** plug with a sure grip center - very rare item, most get lost never to be seen again.
  15. gaskell
    gaskell
    from CO
    Perhaps it is a stailess bone for the previous owners nose!
  16. Side
    Side
    A really well worn door pin.
  17. TheMonkey
    TheMonkey
    from MN
    ****fer = tuhpeewith
  18. George G
    George G
    Easy,
    It's a knife rest. You use it during fine dining to rest your knife on so the tablecloth doesn't get dirty.
    Am I the only cultured one here?
    Here's one on egay. Look familiar?
  19. Austin296
    Austin296
    wow its a good thing that engine wasnt run with that in there
  20. Austin296
    Austin296
    haha wow i cant believe thats what it was
  21. boldventure
    boldventure
    no wonder the guys in the Miracle Garage could never find that funny buzzing sound that engine always seemed to make...
  22. JF
    JF
    from Utah
    Ok, so upon further inspection I think John Walker is correct, it has been bouncing around back and forth under the intake valve for who know how long. the edges of the little bulbous area of valve stem are all rounded nicely and smooth and shiny from this bolt or whatever it was from bouncing around.
    (makes me wonder what the thing sounded like when it was running ??)
    what's amazing is that the cylinder wall looks just fine, it has hardened insert intake valve seats which may have helped keep it from wearing into the cylinder or valve seat?
    Unfortunatly I think this engine met its demise from sitting for 10 yrs and may have a freeze crack somewere since there was antifreeze in the oil pan and I don't think it came through a leaking head gasket??
    thanks all for the good times, and Laughs trying to figure this out! I'll post a picture of the valve stem once I get it removed, (tomorrow night) hopefully.
  23. Nefarious Art
    Nefarious Art
    from Auburn, Ca
    what's a ****fer? OHHHH I GET IT
  24. Nefarious Art
    Nefarious Art
    from Auburn, Ca
    what's a henway? OHHHH I GET IT!
  25. TraderJack
    TraderJack
    Ok, folks , I have the word on this , Listen up!
    This is the tool that they used in the Navy when your **** scarred up from Clap. Every day you would have to insert this up the **** until your expanded the scars on the inside of the ****.
    You have felt nothing , until you have experienced the glorious feeling of breaking the scars loose inside your **** each and every morning so you can take a leak.
    Traderjack
  26. Jkustom
    Jkustom
    I dunno, that looks waaaayyyy to perfectly symetrical to have been shaped by chance, rollingand bouncing around inside an engine...
    But then again I'm looking at it through an iPhone..
    My initial reaction was a clay sculpting tool, but I think it's too short..
  27. moparmonkey
    moparmonkey
    from NorCal
    I agree. Its perfectly symmetrical, there's no way that would have happened rolling around inside the intake. Its too long to flip inside the runner, if it did manage to roll back and forth it still wouldn't create identical complex curves on each end. Plus, it looks small enough to go partially through the valve. Probably too long to get into the cylinder, but if it had been run for any length of time my bet would be a jammed valve.
    Having said that, I have NO idea what it is. What type of metal is it? Almost looks like silver, which would definitely make it some kind of jewelry.
  28. mart3406
    mart3406
    from Canada
    Truly cool! But it looks to only be about
    1/2 horsepower though.:eek::eek:
    mart :D
  29. mart3406
    mart3406
    from Canada
    Since the best one - "a double-ended *****
    for a Barbie doll
    " has already been suggested.
    I'm left with some other equally plausible,
    but perhaps somewhat less likely possibilities.
    Maybe a flux capacitor for a Delorean? Perhaps
    a thrush-resistant cobbelnacker from a ZIL
    limousine?? Or a home-built muffler-bearing
    calibration tool for a Trabant station wagen
    possibly??? Most likely though, it's a piece of
    deadly radio-active space junk from a
    disintegrating North Korean spy satellite that
    fell from the sky, hit your car, p***ed through
    the carburetor and ended up wedged in your
    intake manifold!!! :eek::D
    mart
  30. 51 MERC-CT
    51 MERC-CT
    It's an anti-rotation pin that used to come with adjustable lifters back in the 50's. Here's one in use.:D
