What is it??....Machinists?
Discussion in 'The Hokey Ass Message Board' started by Winfab, Feb 7, 2005.
  1. Winfab
    Winfab
    This "tap" was in a box with other parts I bought at a swap meet a number of years ago. No one I've shown it to has any idea of it's use. Anyone here?
    Here is a description:
    Overall length: 6 1/2"
    Thread cutting teeth section length: 4 1/4"
    6 rows of "flutes" (?)
    12 threads per Inch
    Small end: 7/8" Dia.
    It actually is in better shape than the picture would suggest. There is some etched information on it about "SPL TH".
    Thanks in advance if you can solve the case of the "mystery tap"
    Large end of teeth: 1 3/8" Dia.
      14.3 KB
  2. Automotive Stud
    Automotive Stud
    I thought it was a reamer but it does look like it has threads. Maybe a giant pipe tap, or some other kind of tapered thread?
  3. sickboy13
    sickboy13
    hmmm. i was thinking pipe tap too. the SPL TH did some one put that on there or do you think it might have came that way? I checked my hand book and found nothing like that.
  4. Rand Man
    Rand Man
    i was going to say a pipe tap too. Aren't there any markings on it?
  5. ramrod
    ramrod
    from NJ
    It looks like a tap for a somdrige fitting on a drippelmot valve.I have'nt seen one of those in years.
  6. oldgoaly
    oldgoaly
    the "spl th" would lead one to think "special thread"
    It maybe to enlarge a hole then add threads in one p***?
    tt
  7. Winfab
    Winfab
    The SPL TH marking looks just like it was printed in ink, not hand etched or hand stamped with the little # & letter type stamps. I've been around various types of pipe threads and have never seen any with that much taper. The taper it most closely resembles is like that on drill rods for well drilling but on a miniature scale.
  8. Winfab
    Winfab
    No, you're probably thinking of the single taper somdrige fitting. This actually has the subtle taper of the "barrel somdrige". HA!
  9. It is a pipe tap for tapping out ball valves?
  10. Winfab
    Winfab
    As in; for replacing seats in a br*** ball valve? Hmm..... Maybe it went home in a plumbers lunchbox by accident?
  11. Rocknrod
    Rocknrod
    from NC, USA
    I'd bet that its a pipe tap meant for multiple size holes... Grab a couple different pipe plugs and their size pipes, tap in and see if you get the 3-4 threads before it binds up.
    If it'll give you 3-4 threads, its a cool tool... I'm betting it wont quite do that, looks like a "great idea" thats mostly impossible to impliment!
  12. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    I would guess that it's an **** probe left behind by aliens.:eek:
  13. Winfab
    Winfab
    Rocknrod.....You just might have it! I'd think it might work on 1/2" or 3/4" and up to about 1 or 1 1/4" NPT. I'll check it on some fittings tomorrow. I woundn't think the T.P.I. changes much, if at all, through those sizes.
  14. fab32
    fab32
    HRTH, Interesting theory. YOu wouldn't happen to have any experience with that kind of equipment would you?:eek: :cool: :D
    Frank
  15. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    I'm usally the prober, not the probee.:D
