I run 3 factory Holleys on my Falcon,Tri power if you will. All set to factory specs. 735 CFM total on a 260 CI SBF. Runs like a champ. I run 2 600 Holleys on my Roadster. Factory Ford 2x4 intake. 1200 cfm on a 302 CI SBF ! it screams. But this set up was no picnic to tune. Primary jets are stock but secondary jets are one size smaller than stock with 7.5 power valves. Air fuel ratio is 12 to 1 from 2000 to 7000. It runs a bit fatter from 1100 to 2000. I have overtime run both AFBs and Holleys. Just seem to like Holleys better.
I have an edelbrock on my mild 350 and it works great, except that after a few days the float bowls empty. I've picked up some holleys the last few weeks because they were cheap or free. They're kinda fun to rebuild, they're just so simple. I have a 525,600, and 650, so one of those ought to run alright. I have to think with so many different opinions on them, and experoences, it probably comes down to how well someone knows how to tune it. That, and the same messed up carbs being swapped around craigslist! ;-)
I've always liked the looks of the Holley better so thats what I learned to tune. Even had a guy call once and said his Holley had an off idle miss. I told him what to do over the phone and he had it running great in no time. I know the guy who has the truck now and it still runs great. I buy demons now when I buy carbs (same as Holley design) and have had no problems. And look a whole lot better than Edelbrocks.
I've run a Holley on my '57 for years, and aside from a few hiccups, usually not caused by the carb itself, it has run flawlessly and provided outstanding performance and reliability. I've also used Edelbrocks on a past build, and I have one on my '63 Ford with a 289. Both Edelbrocks have run reasonably well, but never as well as the Holley, and both have gotten awful fuel milage, even for the application.
A proper designed carb doesn't have gaskets below fuellevel that can dry out and start to ****ing leak and burn your car down the next time you start your heap.
It seems to me that Holleys will run well the first time it is tuned, but gets thrown off. I am personally an AFB person. Only when something within goes bad, they are tough to tune. The strip kit you can get has helped me with any of my Edelbrock/AFB problems. Edelbrock carbs work well on cars, horrible on Harleys.
Had a conversation (limited conversation at best) with the Edelbrock/Carter carb tech line years ago..."the 600-650cfm carbs are set up to run on small block fords and chevys with mild RV camshafts"....this is what the rep told me about where the "baseline bench settings from factory" came from...Maybe he did not really know and that was a good guess, I dunno. Thus, to this "bolt on and Go" success SOME people have had...I'm jealous, never had such luck with any performance carb of any pedigree outta the box. Maybe it's because I'm too picky about responsiveness and performance. HeHeHe...bolt and go carbs...makes me chuckle Then again, most people think dizzys are also "bolt on and go" too leave that topic for another time -QQ
I've always had good luck with holleys. It's all about the tunning, and matching components. I've run several tunnel ram setups on various Fords I have owned, They all ran great on the street with Holley's when properly dialed in. It's not rocket science but you do have to do a little homework. Proper jetting and shooter sizes, to drilling ****erflies, with large overlap cams make a world of difference.
Tuning carbs is so much easier if you have a vacuum gauge and a tach.. Learn how to use both and you'll become a carb tuning wizard in no time... Kinda like yours truely... ..
I will take a Q jet over a AFB/AVS/ any day of the week the problem is people dont rebuild the lower body and they **** air. If you drill out the ****er fly shafts and press in new bushings they will out perform a AFB/AVS all day long shave the pump 10.000 and pick up lower flow and they will kick ***. love the new holley street avangers carb out the box close the hood.
Biggest problem is that everybody bolts them (edelbrocks) on and wants to forget about "it". Edelbrocks Want only 4-4.5 lbs. fuel pressure and many of us bolt them on our SBC's or whatever motors and gripe because they run "fat" at idle. No adjustment in the world will fix it till the fuel pressure is right. Most rebuilt "stock" pumps put out more than is needed and need to regulated down. I've been a Holley guy all my life and like to tune and tweak. I had a Edelbrock 1406 ele. choke unit that I couldn't get to run worth a **** either. I fiddled, turned, tweaked until I was in fits. I finally went to the edelbrock booth @ the US Nationals and told the Tech. rep "carbs aren't worth a ****". I told him my problem and he told me the fix: FUEL PRESSURE. He told me to bring the car in and he'd check it over. I used my buddies entrant p*** went in and they put it behind the booth and went through it. Found only 1 thing wrong, FUEL PESSURE!!! They went and got a regulator, put it on for free, tweaked the carb, free, and sent me and my Hot Rod Home, running Good!! Moral of story, Just because it's "Stock Rebuilt or new" doesn't mean it is. After 51 years of living, I find too many guys on here who can't and don't take the time to find out how to do something correctly. I stiil ask questions, and will always ask till I understand the "fix".
I had a Holley that ran like **** I replaced it with a Edelbrock an never had a problem. That was 3 years and 18,000 miles ago.
I have never had a problem with an edelbrock carb. I bought a new holley once and it ran like ****. The holley techs were nice and helpful but it we never could get it right.
A slab throttle shaft is a vast improvement over a slotted shaft??? A split pump well is a vast improvement over a solid well with a check valve??? A plastic pump with a neopreme skirt is a vast improvement over a br*** pump with a leather cup??? Yes to all of the above, IF you happen to sell replacement parts, maybe not so much if you are an owner. Jon.
Due to the design of the different types of carbs, you run which one you need the benefits of. Edelbrocks have metering rods to regulate fuel flow at part throttle, which makes them good for around town driving. Holleys are best used for wide open throttle, unless you jet them down, but they dont transition the best. Bottom line, both great carbs for what they were designed for. I use the Edelbrock for the street and the Holley for the track.
I didn't say things about the original Carter's weren't better, but you feel the need to poke your head in every Edelbrock thread about this. I can't call up and get a NEW Carter, some NOS is available but I have a hard time spending twice as much for a carb that most likely needs going through from sitting on a shelf for 20 years. I have great luck with the Edelbrocks.
Well since there are so many people with opposite opinions and arguments to support both sides about these carbs, it must be the tuner. Some tuners think like the Holley works, some tuners think the AFB works , some tuners think like a Q-jet. Some tuners understand all of them, some only of them. Kinda like a Sax player that can't play a guitar, neither one can sing! and then there's Elvis
I like them all, Holley, Carter, Predator, Edelbrock, Autolite, Motorcraft, Rochester, etc., but I know how a carb works, and I know that throwing another brand on a car is probably not going to fix anything. What happened to tuning and tweaking things on a car. All I hear is "I wanna throw something on there and I don't want to mess with it." Or, "Give me an HEI, or Pertronix because I don't want to have to ever set my points." The traditional car gods are probably cringing at that kind of behavior.
Only carb I have ever had a problem with is a Demon. I'm not smart enough to tune them. I ran Carter AFBs back in the '60s, we all did, I can still hear in my mind the sound of an AFB on a 283 bored to 301 hitting 8 grand at the end of quarter on a two lane country road at about midnight as I stood at the line in the middle of the road after flagging them off, awesome sound. Still got a pair of AFBs, I now run Holleys and Edelbrocks both without any problems.
Never had a bad experience with either - both are good designs that have their limitations. Most of these carbs are very good.....its the tuner who does'nt know what they're doing and end up blaming the carb.....usually. How many guys actually start with a decent carb to begin with, c, clean fuel filters, clean air bleeds, emulsion tubes, tight throttle shafts etc? How about using a vac gauge, gas ****yzer etc to get the fuel curve right? Any POS carb regardless of brand will run like **** its its in **** condition or used in the wrong application. Nor will a new carb fix a clapped out junker engine with bad rings and a huge cam. Knowledge, patience and fine tuning once and for all is the name of the game with either design. Once dialled in, leave it be and drive - unless you're racing. Had very good success with both Holly vac sec, DPs and Carter TQs. Take the time to learn about the carbs, how they function and maximising their potential with your combo. Educate yourselves then have a crack at dialing it in - properly. Rat
I have both also. The only problem I've ever had with the 650 Holley's is blown power valves. I have a 750 Edelbrock on my '36 and once it was "tuned" the thing runs great. The Camaro run's a 650 Holley and has for 30 plus years without any real issues other than a couple Power Valves and rebuilds...........
Lots of good info here guys, but all about big ****ie things. Anyone have anything to say about the new Edelbrock 94 Two-Barrel Carburetors? Been thinking of putting one on a side valve.
