Hot Rods What is it??
Discussion in 'The Hokey Ass Message Board' started by tav, Mar 2, 2019.
Tags:
  1. tav
    tav
    Hi all!
    So I bought this old car shell being told it’s a ‘29 dodge body (I honestly didn’t care what make it was as I just want to build a rod with the late 20’s/early 30’s shape), but now that I’m looking into it more, I can’t find a picture of a dodge with the same lines in it. It’s the swage line that comes up behind the rear most side window that has me confused, and I’m led the believe that dodges of that age had the drip rail above the windows welded to the body (I could be wrong). If anyone can enlighten me to what it is, it would be greatly appreciated!!
    Thanks!!
  2. Thats a big one. Looks solid except that all the wood has been stripped out. How about a pic of the firewall and rear window. The window frames look pretty simple with no double reveals/swages. Last side window is symetrical which you don,t often see. Maybe it,s an Aussie built body which you probably won,t find using google. Could even be something British.
  3. tav
    tav
    There’s the front, I’ll have to get a picture of the rear window in the morning. I’ve been told it might be a desoto too.
  4. I would say Desoto. Here,s a 1931 cowl. Your cowlband is missing, can see the holes though. Looks like you have plans for an extended pickup cab.
    harpo1313 likes this.
  5. BJR
    BJR
    Those doors don't look right for that body. The belt line doesn't line up and the front door is the wrong width.
    squirrel likes this.
  6. scotts52
    scotts52
    I'm a long way from you but I have a 29 Dodge frame I'm trying to sell.
  7. squirrel
    a view of a 31 desoto sedan from the rear
  8. BamaMav
    BamaMav
    from Berry, AL
    Of course they don't line up, the body is on blocks, the doors on the ground. You can see how much lower just by looking at the door top to body opening....
  9. squirrel
    the front door does not match the rear door, you know....
    BJR likes this.
  10. 54vicky
    54vicky
    I agree with jim and bjr the front door does look wrong top of door (window frame )midbelt mold sure look different.surprised no one recognized the vertical swage at rear window.AACA site may supply answer under what is it? good luck
  11. BJR
    BJR
    The rear door when you raise it so the belt line matches the wheel cutout will not fit as it fits now. The front door has a different profile on the belt line and the door top. The body has had the rain gutter removed, you can see the holes around the top of the rear quarter window where it lines up with the body line.
    54vicky likes this.
  12. 54vicky
    54vicky
    hopefully you do not take these comments as critical just making comments on what we see hard to be accurate if parts do not match.again good luck
    King ford and BJR like this.
  13. 31Dodger
    31Dodger
    The body is a 1930 Plymouth as evidenced by no cowl lamp mounting holes.
  14. Fordors
    Fordors
    I’m far from being an early Mopar expert but doesn’t a ‘31 Plymouth have a longer quarter window opening than the body shown? Thirty years ago a neighbor had a ‘31 Plymouth 4 door hot rod and it had an oval rear window which I believe the ‘30 also had. I’d be interested to see the rear window of the OP’s body. Post a photo of the back of the body if you can.
  15. 31Dodger
    31Dodger
    Yes....1931 Plymouths have a longer quarter window and an oval rear window. You can see that the car body in question has a rectangular rear window. Here is a 1930 Plymouth "U".... 1930 Ply U.jpg
  16. 31Dodger
    31Dodger
    All of the Chrysler product sedans had the drip rail.
  17. Fordors
    Fordors
    Here is where my confusion comes in, the above photo is identified as a ‘30-U and the 1/4 window looks to be longer than what the OP has and more importantly the rear window is oval.
    So the question is- where there two different 1930 Plymouth sedan bodies?
  18. 31Dodger
    31Dodger
    Yes, I believe there were two types of 1930 U bodies. The first series have the rectangular rear window and the later ones have the oval and continued the oval into 1931.
  19. tav
    tav
    The front door is definitely off something else, it just came with the car. I posted about this on a Facebook forum too and the general consensus is that it’s a ‘29 Desoto.
  20. banditomerc
    banditomerc
    ...that's very obvious to a seasoned old car ofisionado [emoji15]
    Sent from my SM-J727T using The H.A.M.B. mobile app
