Hot Rods What is it?
Discussion in 'The Hokey Ass Message Board' started by 61gasser, Apr 22, 2021.
  1. twenty8
    twenty8
    This is a better pic of a '28 Whippet firewall. Note the position of the 5 vertical beads and the holes.
    I think you are seeing a trick of the light on the rolled edge of the firewall and mistaking it for a bead.......:)
    The OP's pic is a little hard to make out, but I am definately leaning toward 1928 Willys Whippet Model 96.
    Penetrator and Stogy like this.
  2. squirrel
    sure could be!
    Stogy likes this.
  3. Stogy
    Stogy
    :rolleyes:...Actually that Whippet engine bay pic you posted has a grey pump or filter on the p***enger side and if you look towards the center there is a wiring hole and you can see them both on Ole rusty...
    The bumper looking solid perhaps has an accessory gravel shield in the center...I still question the front fenders lacking the details of the clearer samples and the beltline under the door handle but maybe it had a double pinstripe back in the day...​
    ClarkH likes this.
  4. twenty8
    twenty8
    The fenders and bumper do look more like the ones used on the tourer model. It wouldn't be the first time (or the last) that parts on hand from different models in the range were used together at the end of a model run. Waste was a dirty word back then.........;)
    Stogy likes this.
  5. big bird
    big bird
    A lot of the details are consistent with the Whippet: Fenders, firewall windshield header, fender style hinges, door handle location, door shape, etc.
    I think the "Double Body Line" might be the top and bottom edges of the raised body line.
    As far as bumpers go...its nearly 100 years old. Anything could be swapped on at this point
    Stogy and twenty8 like this.
  6. Lil32
    Lil32
    Stogy
    "how much does a Henway"
    Stogy likes this.
  7. Stogy
    Stogy
    Whats a Henway...2 or 3 pounds...;)...now what the heck is a Leaverite...I couldn't find anything with any wheels that's for sure...:p
  8. 51504bat
    51504bat
    Leave it right there
    Speed Gems and Stogy like this.
  9. Stogy
    Stogy
    :p...that may be exactly what happens to it...that went right over my head...:D
    Speed Gems likes this.
  10. HJmaniac
    HJmaniac
    Here is an Idea for it.
    '27 Whippet
    Fitty Toomuch likes this.
  11. HJmaniac
    HJmaniac
    Here is one with the bumper that is in the pic
  12. ironfly28
    ironfly28
    from Orange, CA
    What's a ****fur?
  13. ironfly28
    ironfly28
    from Orange, CA
    I believe we're looking at a 1928 Durant Star M-2 the door handle and hinges are in the right place and the fenders are similar...hard to find a GOOD photo of a two door but here's the Quattro port version for comparison.
  14. twenty8
    twenty8
    Nope. Looks very similar but the door hinge position is not even close, and the Durants of the era had only three hinges. The mystery car has four hinges, just like the Willys Whippet, and in the exact same locations. There were not many marques that had four door hinges. Most only used three, which narrows it right down.
    I'm sticking with '28 Whippet.
    clem, ClarkH and Stogy like this.
  15. Stogy
    Stogy
    A debatable no to this...why the components on the firewall are similar but the notable holes are absent that are visible on the OP and the first 1928 shared by @twenty8
    :rolleyes:...further to the pump or filter noted earlier the highest area circled is the hole the line p***es through the firewall and the circle just below it is the upper mount fastener location for that black cylinder...
    :rolleyes:...this is the 29...now I'm doubting myself...You fellas are good so I will share this to muddy my initial observations above, TB might be correct...the very poor pics are most responsible for the confusion in my opinion...I mean looking at the 29 the double raised areas on the front fenders are non existent on the OP...:oops:
  16. SR100
    SR100
    That's not the same bumper. The mystery car has a spring bumper similar to the one shown on the Chevy earlier, except that its missing its bracketry and center bolt plate:
    In any case, I think the spring bumper is an aftermarket piece anyway.
    It isn't a Whippet. On the Whippet, the bead that goes down the side of the car wraps around under the windshield. On the mystery car, a blend panel slopes down from the bottom of the windshield to the back of the cowl.
    In this case: Whippet bad! :rolleyes: He'll be here all week folks...
    ironfly28, squirrel and Stogy like this.
  17. Stogy
    Stogy
    I think this is why the word Jalopy came about...:oops:
    @61g***er any more pics?...like the dash?
    SR100 likes this.
  18. HJmaniac
    HJmaniac
    whip it good - YouTube
    Stogy likes this.
  19. scotts52
    scotts52
    I think it's safe to say it's a Willys. Most likely a Whippet. Which model though? I have seen a Willys Knight that the firewall matches practically identically. But there's other things that don't line up such as the number of door hinges. Maybe a Whippet that got the Knight firewall for some unknown reason.
    The bolt ons for the whippet and knight seem like the same but reversed on the firewall.
  20. Speed Gems
    Speed Gems
    It looks like @61g***er needs to risk breaking some tresp***ing laws or get one of those monster zoom lenses for his camera.
    ironfly28, Stogy and kidcampbell71 like this.
  21. HJmaniac
    HJmaniac
    1928 Whippet Model 96 Coach Vehicle Profile
    1928 Whippet Model 96 (conceptcarz.com)
    Stogy and scotts52 like this.
  22. Stogy
    Stogy
    That's quite the driver side sun visor...:D
    Observation against...just studying the Hotrod material even if it's rare...I think it is...the stamped inset around the driver side windows seems absent on Ole Rusty see the plank propping the DS upper quarter...
    How many NA Manufacturers were there in 27/28?​
  23. Beanscoot
    Beanscoot
    Does it have papers?
    Ha ha.
  24. HJmaniac
    HJmaniac
    I blew up the pic and of "Ole Rusty" to 500% and I believe I see the inset feature around the windows and the feature under the windshield previously stated in SR100 post.
    Maybe someone versed in photoshop can enhance the photo of "Ole Rusty" for those of who might think we are or are not seeing things.
    List of defunct automobile manufacturers of the United States - Wikipedia
    Stogy likes this.
  25. Budget36
    Budget36
    Kinda looks like it was staged there for yard art.
    Stogy likes this.
  26. Stogy
    Stogy
    HG you've switched to bold text...:eek:...being somewhat PS literate enhancing a **** pic is a little fruitless...your 28 Whippet still ticks most of the boxes to date...I wish the OP would offer up a few better images...doubt ****s...;)
  27. HJmaniac
    HJmaniac
    I didn'tmean anything with the bold. Just a little easier for me to read.
    Stogy likes this.
  28. verde742
    verde742
    Let's all use capitals...
    Stogy likes this.
  29. Stogy
    Stogy
    :rolleyes:...Nuh uh uh!!...dang old Jalopy...:D
  30. greybeard360
    greybeard360
    NO.....
    Stogy likes this.
