What is it?
Discussion in 'The Hokey Ass Message Board' started by Kerry C, Sep 18, 2012.
  1. Kerry C
    Kerry C
    from MN
    I had the chance to get this old Ford for cheap, like haul it away.
    They thought was a 35 truck, flathead & ******, and a over drive?. frame was shorten and it has a heavy duty rear end in it, not sure if it is a Ford rear end or not.
    thanks for any help!
  2. daddio211
    daddio211
    Grill is a '36 Ford p***enger car.
  3. tb33anda3rd
    tb33anda3rd
    somebody was building a "doodlebug".
    what is your plan?
  4. spiders web
    spiders web
    36 ford with wide five wheels. Need alot but still cool.
  5. F&J
    F&J
    Looks like a Model T truck worm drive rear, Model TT is what those bigger T rucks were called.
    But I am wondering what that mini gear box is? Is it part of an overdrive turned backwards?
    Try to put up pics of that part, if you get the car and pull it apart.
  6. rusty bill
    rusty bill
    Not an overdrive but a 1928 Ford truck underdrive.
  7. brigrat
    brigrat
    from Wa.St.
    Rusty bill, with all the **** you have stashed around can't you find a better Avatar!
  8. BOWTIE BROWN
    BOWTIE BROWN
    WTF......was the question ?
  9. bigboy308
    bigboy308
    from Merlin, OR
    Not sure of make, but most likely an auxiliary after-market trans for "TT" Possibly a Warford?
  10. The37Kid
    The37Kid
    The TT and early AA worm drive rears do look a bit alike, what is in the photos is an AA, the wheel studs are the tip off. The gear box is a High Low that was a factory option. Bob :)
  11. Pensive Scribe
    Pensive Scribe
    I have one of those diffs. It's a ruxtel heavy duty two speed. Mine is out of an AA.
  12. n.z.rodder
    n.z.rodder
    Looks like someone cut the **** out of everything to make it fit!! That's a lot of work to bring that one back. How cheap was it?
    Scotty
  13. Kerry C
    Kerry C
    from MN
    Thanks everyone for repling, I have been collecting parts for awhile to build something. So far model A frame with a 8 3/4 rearend in it. A 1924? Ford Touring body, 3 grills, a few sets of headlights, other misc. parts. I saw this truck & dug the rearend in it and haul it home. I do recycled metal sculpture, so I get to do alot of picking at farms. Get lots of free stuff & have never payed over $200 for anything.
    Thanks again.
    Also have a 41 Zephyr coupe pro streeted,not finished, may go with a g***er look.
    64 Sunbeam Alpine that will get a V8 in it.
    Just finished 61 Ranchero that is pro streeted
  14. 38Chevy454
    38Chevy454
    That Ford truck model AA rearend is good for yard art. Someone was building a doodlebug, common to use a heavy duty truck rearend for the lower gearing. That also would support the underdrive attached to the trans.
