Customs What is the best bedliner to use as undercoating?
Discussion in 'The Hokey Ass Message Board' started by BJR, Apr 27, 2016.
  1. BJR
    BJR
    OK so I did a search for the best undercoating to use. Most suggested bedliner as the best product to use as undercoating. I need to do something to the underside of my 49 Buick. The body will be off the frame to make it easier. What spray on bedliner should I use? I will spray it myself.
  2. tb33anda3rd
    tb33anda3rd
    i have used both SEM and UPOL both worked fine. only thing i don't like about it is they are too shiny.
  3. willymakeit
    willymakeit
    I cant offer a good one. Used the one sold by Oreilly's and it looks to be a mistake. It is peeling off. Truck has been kept inside so no exposure to elements.
  4. indyjps
    indyjps
    UPOL Raptor, I've sprayed it in a few trucks, it's in my daily driver bed now for 7 years no fading, chalking, and the only thing that beat it up was dragging steel tube in and out, hell that will scratch concrete.
    UPOL also make a similar coating called gravitex with a finer texture, and made to be topcoated. I shot this on the bottom of current OT project. PPG DP90, gravitex, then urethane over it. The topcoat is overkill, bit I wanted even paint color on the body, suspension etc.
    tb33anda3rd likes this.
  5. Barn Find
    Barn Find
    from Missouri
    I'd worry about anything like that which could hold moisture.
  6. slimcat7m3
    slimcat7m3
    I always use wurth sks stone guard. It is an undercoat, not a bed liner and it can also be top coated. It goes on super nice and even with the correct gun.
    rockable likes this.
  7. Torana68
    Torana68
    from Australia
    +1 for wurth, if you dont know it looks like the stuff under Mercedes and BMW , generally painted body colour after it dries. (water clean up)
  8. chopolds
    chopolds
    from howell, nj
    Any will do a good job, if they are the 2 part ones, undercoat and hardener. I stay away from the single can type, they never seem to dry, stay sticky, soft.
  9. I can not give a name offhand, but I bought rattle can bed liner at Lowes in 2009 and sprayed bottom and top of the floors. Then had to do a little welding on the inside, a brace we forgot. The darn stuff only "burned" off about an inch from the weld. Touched it up and went on down the road. I can not vouch for the interior as I have not had the carpet up. Underneath is all intact. The car has been driven over 10,000 miles. Good syuff.
    Ben
  10. Use actual flexible undercoating. It is nothing like the **** sold as add-ons in the 60s and 70s.
  11. BJR
    BJR
    What about Body Schults
    spikeshotrods likes this.
  12. Just fine. that is the stuff I prefer. BTW, it is Shutz
  13. theHIGHLANDER
    theHIGHLANDER
    Put me in the Shutz camp too. Dries hard, stays put, cleans up nice too when you want to show off a bit. In restoration many "wartime" cars (40-47) had an asphalt undercoat applied on most of the floor, I always replace it with Shutz if it's a body off job. Won't get all brown from dirt and heat, more like rubber than undercoat.
  14. prpmmp
    prpmmp
    Prep is everything!! What is recommended? Sand blasting would probably be best but not easy! Removing all dirt and grease(duh),sanding 40 grit for bite? Pete
  15. krylon32
    krylon32
    from Nebraska
    I have used 3M Body Shults on floors and fenders since it came out. Stays flexible and doesn't tend to peal. Little pricey but has worked for me. Also paintable.
  16. BJR
    BJR
    The whole under side of my Buick is covered in surface rust. How should I prep it for Body Shutz?
  17. Gman0046
    Gman0046
    I wouldn't use undercoating. All it does is hold moisture.
    Gary
  18. krylon32
    krylon32
    from Nebraska
    Normally my floors and fenders are clean and epoxy primed for Body Shults. I've never had a problem with rust out or peeling.
  19. One time I tried an asphalt crack sealer for driveways on the underside of the hood on an off topic ride. Didn't smell too bad and after the truck turned into a Wisconsin rot box, the underside of that hood looked brand new. I don't think I would do it again, but that particular product worked great.
  20. BJR
    BJR
    Just a follow up, I ended up using Body Shutz. I worked great and looks good. Thanks to all that replied.
  21. bondolero
    bondolero
    I use UPOL Chip Guard, nice even texture and paints over nicely. Same as above for painting rockers, etc
    on new cars with textured protection. Their brands are usually cheaper than the major US brands.
  22. ChefMike
    ChefMike
    3 M Shultz I have used it a few times does a nice job and it does harden as I heard people say it stays soft I haven't found that to be the case. it protects well
  23. gimpyshotrods
    gimpyshotrods
    Nothing non-catalyzed, if you are sticking with bed liner.
    I like UPol Raptor inside of trunks of street cars. If you are actually going to use it as a car, it keeps things from getting messed up very nicely.
  24. blowby
    blowby
    from Nicasio Ca
    So I was at harbor freight with my 20% off coupon burning a hole in my pocket. Bought a gallon of bedliner, 40 semolians. Rolled it on some beat up trailer fenders, didn't try to even up the finish much. Hard as a bear's **** today. Reviews are great, we'll see. I'll probably at least do the bed of my hot rod, and try not to keep going.
    https://m.harborfreight.com/124-fl-oz-iron-armor-black-truck-bed-coating-60778.html
