What is the best way to widen a fender?
Discussion in 'The Hokey Ass Message Board' started by megawatt220, Jul 3, 2012.
  1. megawatt220
    megawatt220
    HI All I have a1936 chevy sedan that needs wider rear fenders. How do I go about this? Thanks
  2. metal and welding then make it straight prime paint
  3. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I have made 2 inch wider AD truck fenders by starting with two sets of fenders. I cut one set at the bolt flange and the other set just two inches in from the flange. Then weld. Another option would be to split the fenders and add a strip of metal the amount needed.
    The ones I did are out back in the s**** pile. Made the truck look like a 1 ton.
    John
  4. oldolds
    oldolds
    Buy fibergl*** fenders that are 2 inches wider. Not a fan of fibergl*** but bang for the buck 2 inch wider fenders are good.
  5. OLDSMAN
    OLDSMAN
    On then 42 Chevy I am building, I cut off the mounting flange, and added a 1 1/2 inch strip of metal. A lot of work, but the fenders look great when done, and that did the job to get the tires covered again
  6. jan bogert
    jan bogert
    buy resessed rims if u have the room.
