Technical What is the Torque Spec - 37 I-Beam to Wishbone bolts??
Discussion in 'Traditional Hot Rods' started by studebakerhawk, Mar 26, 2023.
  1. studebakerhawk
    studebakerhawk
    from Colorado
    I'm putting a new dropped axle under my 37 Coupe with new "Perch Bolts" - What are they supposed to be torqued to ?
  2. alchemy
    alchemy
    I think the tight fit of the wishbone yoke over the axle is more important than the torque on the bolt. Make sure you shim any slop out of the joint, then just tighten the nut to damntight. I wouldn’t think you need reallydamntight.
    clem and Tman like this.
  3. Yeah, if it snaps back off a Qtr turn
    GordonC and Papas32 like this.
  4. studebakerhawk
    studebakerhawk
    from Colorado
    It actually had a pretty close fit - so I just did damntight -- Thanks !!
