Technical What is this ?anyone ever seen this before.
Discussion in 'The Hokey Ass Message Board' started by Mitchell Rish, May 8, 2025.
  1. Mitchell Rish
    Mitchell Rish
    from Houston MS
    IMG_4242.jpeg IMG_4244.jpeg IMG_4243.jpeg IMG_4244.jpeg IMG_4243.jpeg I have a friend that acquired a 58 Chevy truck. It has been converted to 5x4/ 3/4 pattern. I suspect the normal method. 64 and down hub and brake drum on the stock spindle. here is the weird part.
    The p***enger side /spindle has this steel bracket and cylinder bolted to the back. And it looks factory. What is it and what does it do.
    Also remember that I’ve had a dozen or more 55-59 Chevy trucks. 1/2- 3/4 - and 1 ton but I’ve never seen this before.
    Sharpone and chryslerfan55 like this.
  2. Bandit Billy
    Bandit Billy
    Google images says that doesn't exist. ****tail shaker? I'll be interested to hear what the brain trust says.
    Sharpone, winduptoy and chryslerfan55 like this.
  3. Oneball
    Oneball
    Looks like a m*** damper. 2CVs we’re the most common production car with them.
  4. squirrel
    i recall seeing that on a GMC, that might have had original power steering...but it's been ten years, and my memory ain't so good any more.
    Is there anything inside the tube?
  5. Bandit Billy
    Bandit Billy
    Thats what I meant by ****tail shaker, 1st gen Camaro convertibles had one in all four corners but not on the wheels.
    Sharpone, Algoma56, Spooky and 4 others like this.
  6. K13
    K13
    rod1, warbird1, Sharpone and 6 others like this.
  7. Davesblue50
    Davesblue50
    Corvair convertibles had the ****tail shakers also.
    Sharpone, Spooky, winduptoy and 2 others like this.
  8. lostone
    lostone
    from kansas
    ****tail shakers were used on a few gm products back in the 60's ragtops.
    First one I remember seeing was on a 67'firebird....
  9. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Good place to hide a gallon of shine.
  10. That was my first thought also. My 68 Firebird conv has 2 in the trunk.
    Sharpone and Bandit Billy like this.
  11. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    I was going guess that it was a place to hide a Beer when the Wife came into the shop !
    VR&C.
  12. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Wow. Live and learn. Never seen one in my life.
    I am interested in the axle ***embly for obvious reasons. Thanks Guys.
    rod1 and Sharpone like this.
  13. ronzmtrwrx
    ronzmtrwrx
    That’s a first for me too. Interesting.
    Sharpone likes this.
  14. 49ratfink
    49ratfink
    never heard of such a thing.. o_O
  15. brady1929
    brady1929
    Condom holder/storage?
  16. Squablow
    Squablow
    Super weird, I learned something today. Odd that this truck only has one, the book says they were supposed to be on each wheel. Not sure why someone would convert this truck to 5 lug and remove one of those but leave the other one in place, that's baffling.
    Sharpone and seb fontana like this.
  17. seb fontana
    seb fontana
    from ct
    I think the left side broke off, I think I seem remnants under/between steering arm and spindle.
    Sharpone and Squablow like this.
  18. Mitchell Rish
    Mitchell Rish
    from Houston MS
    It seems strange to me also that there would be only one.
  19. 1971BB427
    1971BB427
    from Oregon
    Those axles were converted to 5x4.75 drums from 1949-54, not pre 64. When doing this the stock backing plates for the 6 bolt still work, so whatever that is was there prior to the conversion. But since it's sandwiched between the backing plate and spindle it would be easy to remove and clean things up.
  20. '29 Gizmo
    '29 Gizmo
    from UK
    Ned Ludd likes this.
  21. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Now you know why I posted. I have never seen this before . If I get the axle / It will leave. lol
  22. Ned Ludd
    Ned Ludd
    Early 2CVs had inertia dampers because conventional dampers would run counter to the suspension interconnection. The other way would have been dampers inside the pots, which would have required making the pots openable for service. The later horizontal telescopics were a bit of a compromise, possibly enabled by going from steel to rubber for the volute springs.
    I really need to read up, but it seems to me that the limits of inertia damping are that they necessarily involve adding m*** overall, and that the additional m*** is small in relation to the m*** being damped. It did occur to me many years ago that cycle fenders could be carried on damped springs. That would reduce unsprung m*** — though at least half the problem with unsprung m*** is that it reduces sprung m***, which separate sprung m***es would not solve.
  23. Toms Dogs
    Toms Dogs
    from NJ
