What is this motor?
Discussion in 'The Hokey Ass Message Board' started by PunkRodder, May 10, 2008.
  1. Drive Em
    Drive Em
    Grab it. There is no such thing as a junk FE engine, they are all good-352, 360, 390, 410 and 428. My '69 F-100 has a 360 that will do anything I ask of it, and it has 200,000 miles. I built a streetable 390 for my buddies 4,000 lb. '64 Galaxie, and it runs 14.50's in the quarter, and we are at 4,100 ft of al***ude. A 360 has the same 4.050" bore as a 390, so a 390 is only a crank swap away. Stick a 3.98" stroke crank in it and you will have a 410. Parts are not small block Chevy cheap, but they are very reasonable to rebuild, and parts are available at your parts store.
  2. stretch 1320
    stretch 1320
    It would make a nice topper for a load of s****! Junk that ****!
  3. PunkRodder
    PunkRodder
    I will go back out and take some more pics. I like the idea of it being way over the top.
  4. Splinter
    Splinter
    OK-it's got what looks like only 2 bolts on the lower valve covers...that's FE. the Cleveland/Midland family and the 429/460 family both had 4 on the lower side of the valve covers. To know for sure, when you go look at it, check 3 things...first, on the bellhousing, is there a flat spot on the top with two bolts at either end (right below the flat mating surfaces of the intake manild on the back of the block)? If so, it's a smallblock, wither Cleveland or Midland, can be worked with. Next, is the Bellhousing bolt pattern almost perfectly round? If so, it is definately a Big block Ford, either FE or 429/460 family. How do you tell the difference? The FE's are really weird in that the intake manifold tucks underneath the valve covers. You actually have to take the rockers and rocker shafts off to remove the intake manifold on an FE. There you have it.....
  5. RichFox
    RichFox
    The FE engine is no good at all. Shelby would never have used one in the Cobra. Those 427s were something else.
  6. Pir8Darryl
    Pir8Darryl
    My old man had a factory 406 in a '62 T-bird when I was a kiddo. That thing would run like hell! It never seemed to have a top speed or redline,,, just kept going and going.
  7. tommy
    tommy
    You'll get people that love and hate every engine that was ever produced.
    The biggest complaint that I heard about the later run of the FE Fords was that they were gas hogs in pickup trucks of the 60s-70s. Nobody complained about lack of power but they were thirsty.
    To me it's not the type of engine that I would build a car around but if it fit into my over all plan I'd go for it. I'm going to dress up a 352 to look like an early HP FE. The 401 and 406 were legendary in the early 60s.
    Take one out of a 2 1/2 ton barge and put it in a light hot rod or g***er and you'll get plenty of grins.
  8. BillBallingerSr
    BillBallingerSr
    from In Hell
    I like it when people call them junk, I just get cores for free then. The FE is a very versatile engine, some are still holding national records in drag racing. And, respectfully I have to say in a bomber/claimer cl*** stock car they wont even allow the 352 because they will kick the **** out of a 350 Chevy on dirt. They only allow Windsors breathing through the drinking straw stock heads. Pull off the intake on that POS and you will see why. 2.03/1.55 valves and ports that flow very well for the displacement. Rebuild it as a 390, put a Performer RPM on it, a nice solid lifter cam, some headers put it in the A and enjoy. Put a deeper sump pan on too and the oiling will work just fine. See the port in my avatar? Minor work on a 352 head.
    Here is a picture of a worked late model smog head that is going on my .060 over 390, they were on a 428 that was running mid 10's in a '69 Mustang. These heads originally came off of a 360 truck and were ported by Vince Jamora. 2.15/1.73 valves
  9. rustyford40
    rustyford40
    from Mass Bay
    You are trying to teach old dogs. But yes.
  10. Capt. Zorro
    Capt. Zorro
    I bought a new 1966 Ford with a 390 in it and ran the **** out of it. Tore the clutch and transmission out but the engine was still going fine when I traded it in 1969. I've got a 428 in my A Coupe, but it's on a Deuce frame. The FE is a little larger than the "700 club engine". If you loose the cast iron intake manifold (the heaviest known to man) and put a set of Edelbrock heads on it the weight reduction is significant. I dare say that it would be less than a flathead and have a few more horsepower.
    Do a search on Ford FE here and on Google and you'll be able to find lots of info on these.
  11. tjm73
    tjm73
    You don't know much about FE's I take it. Not much more expensive than any other big block and will make bucket loads of hp and torque. The red headed stepchilds are the 352 and 360, but the 390, 410, 427 and 428 FE's make damn good power.
  12. You thought wrong ...
  13. 427's in Cobras were FE motors and the Cobras that won LeMans had 428 FE's in them ..
  14. That is a FE you can look at the front of the block on the drivers side and it will probably have a 352 cast on the block i have seen a few that had 390 cast there. Those arent that bad of a engine all the 55 and 56 fords i had about 40 some years ago i would toss the Y block and install 352s and 390s. I had one out of a 59 galaxie cop car that was a interceptor that i put a stick behind with 325 gears that was a very respectical drag car. you can bore that 360 .030 and use 390 flat tops and raise the compression and with proper cam and intake and headers it will scream. OldWolf:cool:
  15. Pir8Darryl
    Pir8Darryl
    Fuel: A source of power or stored energy
    Electricity: A source of power [that can be stored, as in a battery]
    Motor: Any device that converts a form of transfered or stored energy into motion
    Engine: a 3rd person term used to describe the mechanical motion of a motor.......
    So you are correct, but you are also wrong because the terms are inerchangable.
    Electricity is a form of fuel, and fuel can be described as electricity.
    A motor instantly becomes an engine once it starts to do work.
  16. PunkRodder
    PunkRodder
    I am going out to take more pics. I would like to know exactly what it is. Do you think I will be able to edge this thing in to my A frame?
  17. tommy
    tommy
    Look on the valve cover for a decal. Some of those years had a decal that listed the size of the engine a**** other things. Not a sure fire answer but it doesn't seem to be altered too much from the way it came from the factory so if it's there, it's probably correct.
  18. nexxussian
    nexxussian
    You should be able to fit that into an A frame, the firewall, that might be another matter (unless you move 'things' around some).
    FWIW I had a 73 Ford F250 4X4 for a little while that had a 360. ****py carb, at least one burned valve (when I got it) but it would still drag that old truck around just fine. I had planned to do an overhaul on it, figured on a PAW or some other budget OH kit with a 390 crank, wanted to hop 'em up even then :D (this is when I was 14 or 15).
  19. nexxussian
    nexxussian
    Oh yeah, see if you can get the box that goes with that distributor, as it should be a Duraspark (or whatever Ford called their electronic stuff then). It should work fine till you can afford something prettier.
  20. 6t5frlane
    6t5frlane
    from New York
  21. Silhouettes 57
    Silhouettes 57
    700 Club.... That's A Good One!
    My first FE was in a '67 F250 and it was a 352 with a granny 4 speed trans and as far as I'm concerned the best vehicle I've ever owned.....EVER! Year after year we took that thing on vacations loaded for a family of 5 with a camper and most of the time dragging a small utility trailer then I would work it all week long. My daughters cried when I sold it.
  22. PunkRodder
    PunkRodder
    Well if this motor doesnt have a spent block I am going to get it. MNay be a ***** to fit in to my A but with a 9 inch rear it may be a monster.
  23. fordf1trucknut
    fordf1trucknut
    From the pics it looks like the truck is a 2wd. 73-77 2wd trucks could have the 360 OR a 390. 73-77 4x4 trucks had a 360 as the only v8 option.
    If the drivers door is still on the truck Write down the numbers and put them in the vin decoder to find out if the truck originally came with a 390.
    http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi
  24. fordf1trucknut
    fordf1trucknut
    Also take note of the other codes opn the data plate... the rear may have a limited slip centersection in it.
  25. PunkRodder
    PunkRodder
    I did look at a white sticker on the door. Most of the numbers were worn off. I did not get a good look as I was leaving when I spotted it. Of course all the vehicles were running when they got parked. Looks like someone took the clip off to get to the motor as it is sitting next to the truck. Not sure why they changed their mind. The thing still has the key in the ignition so I may be able to hook a battery and see if it cranks.. Who knows the block may be full of water from sitting. Not sure. Anyone have advice for checking to maker sure this motor is salvageable?
  26. rustyford40
    rustyford40
    from Mass Bay
    No he is right motors are run off wires, engines are run on fuel.
  27. PunkRodder
    PunkRodder
    Oh **** here we go.
  28. triplexkustoms
    triplexkustoms
    so where is the best place to get finned valve covers for a 352?
  29. ncranger05
    ncranger05
    FE's are great motors but it seems theres a couple CI's that people havent posted 332, 352, 361, 360, 390, 406, 410, 427, 427 cammer... or atleast thats what wikipedia says...iirc all parts interchange? but i could be wrong maybe someone that knows a lil better can help ya there
  30. 53sled
    53sled
    from KCMO
    Pull the plugs before you do anything and squirt auto trans fluid in, wait for it, then spin it by hand, if you can. if it spins by hand, you're probably ok to buy it.
