What is this spoon pedal from?
Discussion in 'The Hokey Ass Message Board' started by Hitchhiker, Sep 22, 2011.
  1. Hitchhiker
    Hitchhiker
    Anyone know what this is from?
  2. 91Bear
    91Bear
    from Boerne, TX
  3. coupeHEAD
    coupeHEAD
    Mid thirties Ford.
  4. badshifter
    badshifter
  5. big duece
    big duece
    from kansas
    Ditto that, 32 ford. I just sold one like that, looks like a v-8 one too.
  6. chaddilac
    chaddilac
    Same as early 40s ford pickup too! I sold 2 of them a few months back!
  7. Hitchhiker
    Hitchhiker
    Sweet! thanks guys. I'm going to try and use it in the coupe.
  8. Dirty Dug
    Dirty Dug
    If you sold one like that and represented it as being "32 Ford then someone got screwed. A '32 pedal has a dog on it for a hand throttle and is about an inch shorter than the shown '33 through maybe '40 s**** pedal. Four cylinder cars have a longer horizontal shaft.
  9. i think its off a 41 henway convertible
  10. hotrod40coupe
    hotrod40coupe
    Looks like the one in my '40 pickup.
  11. n.z.rodder
    n.z.rodder
    It's mine, I'd like it back when you're finished with it thanks.
    Scotty.
  12. What's a Henway?
    Sam
  13. go-twichy
    go-twichy
  14. tommy
    tommy
    33-34 Ford V8 P/U. Maybe a 33-34 car? I can't say. I never had one. The 32 Ford pedal is the only year that has a ball for the hand throttle linkage that this one does not have. I'd bet that it will work just fine for a 32 hot rod unless you want to run the hand throttle linkage. At least you have the tin cover for the firewall side that is usually missing on the flea market pedals.
  15. sololobo
    sololobo
    polk salad, Annie! Gaters got your granny! Thanx for the s**** pedal seminar. ~sololobo~
  16. da34guy
    da34guy
    About a pound and a half.:rolleyes::rolleyes::rolleyes:
  17. alchemy
    alchemy
    I think it's from mid 30's pickup. The pedal pad is longer than a '33/34 car. As said before, it's definitely not '32 Ford since it has the longer pad and is missing the side knob.
  18. big duece
    big duece
    from kansas
    I took it right off of a 32 v-8 ch***is firewall, unmolested. IF the "dog" that your refering to is a little tab with a ball on the end, mine had that.
      100.5 KB
  19. 117harv
    117harv
    To make it more complicated, the 32 pedal came in two styles, 4 and 8 cylinder as i have been told...is this right?
    I have several s**** pedals and all are a little different.
  20. alchemy
    alchemy
    The '32 V8 pedal looks like Big Duece's above. The 4 cylinder looks the same inside the car, but is longer to the right side of the engine compartment. And it doesn't point straight up, it leans over a little to reach the carb on the side of the engine.
  21. 117harv
    117harv
    The s**** part on the 32 is more round than oblong as compared to the later ones.
    Thanks for the info alchemy.
  22. Bruce Lancaster
    Bruce Lancaster
    The '33-4 shown is a touch longer in the pedal than '32...from memory I think it fits a '32 firewall, don't know about floor.
    The 4 cylinder versions are much wider and throttle arm goes down rather than up...all '32 firewalls are drilled for both, you can find the holes down there.
    Pretty sure the mounting cup is '32-4 only, and the s****s used later on trucks used two bolt pivots to mount.
  23. Hitchhiker
    Hitchhiker
    Thanks guys. Lot's of good info here. I'm not really concerned if it's 32 or not. I'm just trying to get a general year ballpark. I didn't want to use something from the 50's or later. thanks again!
  24. Bruce Lancaster
    Bruce Lancaster
    I believe onliest difference (unless you need a '32 hand throttle to work!) is a small difference in the length of the pedal, so no worries.
  25. tommyd
    tommyd
    from South Indy
    Huh......really? Sounds like four cylinder cars are just bragging.
  26. NealinCA
    NealinCA
    No, the same mounting cup was used up to 47 on pickups and trucks.
    In my 32 RPU, I used a 40-47 truck pedal that looks just like the one in the original post. The cup side fit with no modification to the 32 firewall, I just had to drill a new hole for the stud, as these fall some where in between the 32 V8 pedal and 4cyl pedals for width.
    Neal
    Cliff Ramsdell likes this.
