Technical What is this thing posing as a deuce grill?
Discussion in 'The Hokey Ass Message Board' started by Barn Find, Jul 11, 2016.
  1. Barn Find
    Barn Find
    from Missouri
  2. hotroddon
    hotroddon
    I'd say it was a home made insert. Probably looked kind of cool back when they did it!
  3. Squablow
    Squablow
    Looks like a '32 p***enger car shell with the original top emblem and hood band on it yet, but with a homemade insert. I'd bet the insert had to be made in two pieces, and that's why it has that center molding.
    WELL worth $400, probably will sell for quite a bit more.
  4. redo32
    redo32
    180761506_1934-1935-chevy-car-upper-grille-section-pickup-rat-rod-.jpg I think think the insert is '34 Chev , give or take a year. Well maybe not. Different pattern.
  5. paul55
    paul55
    from michigan
    Maybe a mid 30's Lincoln?
  6. Barn Find
    Barn Find
    from Missouri
    Lincoln maybe,
    But I still suspect it was more likely that whoever made it had access to an IH truck grill.
    [​IMG] whoever
  7. tfeverfred
    tfeverfred
    Put your balls in a wheel barrow and bid, $500. Then you'll know.;)
  8. To me it looks like a 1935-36 WILLYS grille flattened out and the extra center molding attached to the front side to blend into the surrounding molding of the '32 opening.
  9. redo32
    redo32
    The insert in the '32 shell is wider than the Willys, but the pattern top to bottom is the same , one wide bar & two skinny.
  10. indyjps
    indyjps
    Looking at the eBay pics, the grate pattern in the insert is 1 piece, flat stamped material. Not a welded bar type like youd find on a refrigerator rack. Still may have just been some aluminum sheet and not originally from a vehicle.
  11. Peanut 1959
    Peanut 1959
    I think the IH truck insert (with some other border) is right on the money
  12. oldolds
    oldolds
    I think it may have been a early replacement grill. Maybe custom or JC Whitney kind of thing. I have seen a couple other grill shells with similar inserts that were not OEM.
  13. banditomerc
    banditomerc
  14. HOTRODPRIMER
    HOTRODPRIMER
    QUOTE - Original farm fresh grill with some defects as shown in photos. Rusty but very solid.I've been told that it's off a '32 ford truck.
    It sure ain't a 1932 Ford pickup grill shell! HRP
  15. 26 T Ford RPU
    26 T Ford RPU
    I also say International, around 1936. I had a Grille and Shell off one. It is the same paattern also as my 35 Willys but its too narrow as has been said. JW
  16. dcrogers
    dcrogers
    from iowa
  17. Barn Find
    Barn Find
    from Missouri
    I just noticed every third horizontal bar in that grill is fatter. I don't see that pattern in the IH grill. The Willys grill has that pattern, but as stated is too narrow.
    It is also not a Corbitt grill, but this picture is so rare I just had to share it, anyway.
    belair likes this.
  18. Barn Find
    Barn Find
    from Missouri
    ...and it sold for $400. Seems like a bargain.
