What Is This Thing?!?!
Discussion in 'The Hokey Ass Message Board' started by Scotch Buzzard King, Dec 10, 2012.
  1. I saw this on someone's 55 Chevy project, and I can't figure out for the life of me what it is. Does someone else know?
  2. junk yard kid
    junk yard kid
    looks like a vacuum can. or maybe an oil separator for a pcv.
  3. tfeverfred
    tfeverfred
    Looks like it needs a coat of paint.
  4. 53 COE
    53 COE
    from PNW
    Prob some old snake oil device promising better MPG..........
  5. Hackerbilt
    Hackerbilt
    That'd be my thought.
    Someone retrofitted a PCV to an engine not originally equipped and needed a way to keep it from ****ing oil.
    Hamber C9 (rip) had something similar done for his Deuce roadster and actually detailed its construction here on the HAMB.
    Of course without a close look at the canister and ***ociated bits all that is just a guess!
  6. dad-bud
    dad-bud
    It's a milk-frother so you can make double-shot decaf skim frappucinos on the way home after a long day.
    :D:D:D:D:D:D:D
  7. Early flux capacitor.....
  8. F.O.G
    F.O.G
    from Pacific,Mo
    Pressure lubricator for flatheads with a "Pros***ute" cam, for guys that like to ****
    around town. Very common in the 'fities.
  9. The_Stig
    The_Stig
    The lower half looks like a sediment bowl, judging by the sway clip holding it in place
  10. Hellfish
    Hellfish
    What does the label say?
  11. zeuglodon
    zeuglodon
    I think it's some sort of accessory vacuum reservoir for the wipers.
    Vacuum wipers had an issue of slowing or stopping under low vacuum conditions (acceleration).
  12. Could that be one of those cirgarette ****ers?? The accessory that would **** the ****s into a container??
    Looks like large enough tubing, it's hooked to vacuum, AND it has a container with what looks like ciggie ****s.
    What do I win??
    Cosmo
  13. propwash
    propwash
    from Las Vegas
    if it was for the wiper, there'd be a connection to the wiper. Note that the vacuum for the item comes from the intake directly, but I don't see any tubes to a PCV valve, or to the oil filter. Perhaps a '****-****er' is exactly what it is, but that reservoir doesn't look large enough for a "pack-a-day" puffer.
  14. zeuglodon
    zeuglodon
  15. It sure would, IF that thing were connected to the wipers.
    However, it is not.
    Cosmo
  16. propwash
    propwash
    from Las Vegas
    To 'back you' up, that forum would need a picture of a nearly identical item. I still don't see any mechanical/physical connection by which the wiper motor would benefit from anything that pump/canister/whatzit could do. If it isn't connected, how can any stored vacuum operate the wiper motor?
  17. propwash
    propwash
    from Las Vegas
    If you follow the rubber line that runs from the center (left) of the IIQ (item in question), you can see that it goes around the back of the valve cover, under the wiper motor and over to the other side of the engine where it likely connects to a PCV valve. As someone has also surmised, it's an oil separator for a non-OEM positive crankcase ventilation valve.
  18. Ebbsspeed
    Ebbsspeed
    There is a connection to the wiper motor through that valve looking think on the side of the intake. That valve probably opens at a normal cruise vacuum, which could operate both the wiper motor AND also charge the canister with vacuum. At low vacuum, the valve closes, but you still would have a reserve of vacuum in the canister to operate the wiper for a few swipes across the gl***.
    Of course that doesn't explain the second larger hose on the canister. Maybe its a combo ****-****er and gl*** wiper.
  19. 49ratfink
    49ratfink
    where does the other line go on the other side of the motor?
  20. I don't know. This is the only picture of it he had posted.
    Never seen one, but that concept is the coolest thing I've heard of in a while. :D
  21. I stand corrected.
  22. It looks like an early "green" device. Like a sludge vacuum.
  23. 40FordGuy
    40FordGuy
    Looks kind of like a product called, believe it or not, "Condensator",....it went between pcv and mainfold,..with a silica jell element,....a kind of "heavy hydroocarbon seperator". We saw a lot them in mid to late 70's,....Difference was it had a gl*** bowl, so (I guess) you could see when it needed servicing.
    4TTRUK
  24. propwash
    propwash
    from Las Vegas
    That is not a "valve" coming out of the intake. It's a simple br*** T fitting - one for the wiper motor and one for the item we're discussing.
  25. That makes sense, but what was the purpose of it? Was it early EPA reg requirements?
