Technical What is this tool for?
Discussion in 'The Hokey Ass Message Board' started by rustynewyorker, Apr 16, 2023.
  1. I know the top of it is a slide hammer or bearing tool, a Proto 4056, but I can't find anything like the bottom of it. Solid metal and about a foot long, no markings I can find on that part. Looked at a lot of kits and parts in various eBay and other posts but came up empty. Maybe it's just so old and obsolete there's no pictures online.
    That's a standard card table the tool sits on, to give an idea on length.
    My thought was maybe some kind of tool for rear axle bearings but I can't figure the length on it.
  2. Budget36
    Budget36
    Not sure, but a danged “skinny” pic when clicked on the thumbnail
  3. pprather
    pprather
  4. dalesnyder
    dalesnyder
    It may be a type of bushing installer. Kind of the opposite of what we would use a puller to do.
    When you slam it forward it pushes the bushing in.
    Maybe for heavy equipment.
    rustynewyorker likes this.
  5. lostone
    lostone
    from kansas
    That's interesting, what if it works backwards? As in instead of sliding the weight back towards you, you actually slide it forward towards the tool end.
    If that were the case then it's a driver of some kind. ..
  6. That would explain the lip and the pointed end.
  7. SEAAIRE354
    SEAAIRE354
    With the tapered end you could put it in a smaller diameter tubing and use the tool backwards and put a bell mouth on the tube. It may have been something someone made up as apposes to a special factory made tool. I’ve gotten creative with stuff like that over the years.
    2OLD2FAST likes this.
  8. s55mercury66
    s55mercury66
    from SW Wyoming
    Bushing and seal driver, for what is hard to tell. OD would determine what size, but the specific application could be for a Marine Henway 14 cylinder. Pretty handy piece for someone who needs it.
  9. Hotrodmyk
    Hotrodmyk
    How about a kingpin bushing driver?
  10. jaracer
    jaracer
    The piece on the end looks a lot like an injector cup on a heavy diesel engine. It might be used to install them.
    Hotrodmyk likes this.
