What is this tool used for??
Discussion in 'Off Topic Hot Rods & Customs' started by Jokester, Sep 24, 2025.
  1. Jokester
    Jokester
    A friend found this in his shop and wondered what it was designed to do. It's like a nut driver, but 31/32"!! And a square nut! I can't imagine a tool that size being able to obtain enough torque for that size nut. May not even be automotive. Any ideas?
    thx,
    .bjb
    VANDENPLAS and 210superair like this.
  2. Deuces
    Deuces
    That's a weird square nut driver... Must be Chinese...:confused:
    210superair likes this.
  3. 210superair
    210superair
    from Michigan
    Obviously a driver, I'd say for some specialized job of some sort. Who knows what. Wood boats are like that, I have a few hand tools for wood boats any car guy would look at and say 'wtf is that', lol.
    VANDENPLAS and Deuces like this.
  4. rockable
    rockable
    Try the Garage Journal. Those guys work with all kinds of tools and are really good at id'ing weird stuff.
    Deuces and Rolleiflex like this.
  5. RMR&C
    RMR&C
    from NW Montana
    WAG......some metal grain bins are bolted together and use square nuts on the inside. Maybe an installation tool? Since you're in KS it's a thought
  6. Rolleiflex
    Rolleiflex
  7. oldiron 440
    oldiron 440
    It’s a thingamaginger for a whatchamacallit…
    MAD MIKE, rockable and Deuces like this.
  8. CSng61
    CSng61
    It's a doohickey. We had several around the ranch that were used for keeping dust off of the workbenches. A farm tool that may not have been seen by you city folk.
  9. RodStRace
    RodStRace
    Some good guesses here! Since it's a big square nut with very limited torque, mine is some sort of adjustment for lash, sort of like a steering box.
    slowmotion likes this.
  10. miker98038
    miker98038
    My Dad used to say “ I’m not sure what it is, but it’s a good one”. Sounds about right.
  11. 210superair
    210superair
    from Michigan
    VANDENPLAS, SS327 and Deuces like this.
  12. slowmotion
    slowmotion
    I was thinking this earlier, but wasn't sure how to word it! Thanks @RodStRace !
    RodStRace likes this.
  13. RodStRace
    RodStRace
    @210superair First rule of plumbing is @#$ runs downhill.
    Third rule is leverage is good! I can't see a small handle being used for that!
    P.S. Just found out they make torque pipe wrenches!
  14. RMcCulley
    RMcCulley
    IMG_5012.jpeg Maybe for fill plugs?
  15. gene-koning
    gene-koning
    What ever square nut it was made to tighten or remove didn't require much torque. You don't put much leverage with your wrist on a nearly 1" square bolt head. I'm guessing it is an ***embly tool, place the square nut in the tool, hold it against the hole the bolt is shoved through and tightened with some kind of battery driven tool. The grain bin nut holding driver sounds like a strong possibility to me.
  16. Jokester
    Jokester
    OK, that was fun. I've got two more. The pliers do not appear to be homemade. Looks like a factory piece.
    Deuces and 41 GMC K-18 like this.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Top one will hold on even if one lets loose?
    Bottom one, for turning flywheel?
    Then there’s, do the two work together?
  18. alanp561
    alanp561
    Used to have to work alongside plumbers on powerhouses. They had a slightly different order in their rules.
    "First rule of plumbing is, payday is on Friday".
    "Second rule of plumbing is, **** runs downhill".
    "Third rule of plumbing is, don't chew your fingernails".
    Your "leverage is good" sounds right. I've seen those guys hook 2 ton come-a-longs to a 5-foot-long pipe wrench for 8-inch pipe.
  19. Dick Stevens
    Dick Stevens
  20. SS327
    SS327
    Top one is for carrying large pieces of sheetmetal.
  21. 210superair
    210superair
    from Michigan
    Lol, if you need that much torque to open a drain cleanout you'd better lay off the Wheaties and spinich!
    My drum trap is all copper. Over tightening it would be a bad thing and very easily done. Like br*** fittings on old boats. Maybe that driver was for cleanout access. Maybe not. I dunno.... But I do know not everything in plumbing needs that big ol wrench! Lol.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I can see how that would work.
    SS327 and RodStRace like this.
  23. RodStRace
    RodStRace
    Agree!
    I guess that second one is also a quick handle for something specific. Fairly light due to construction and vertical handle, not super hot (molten gl*** would tear it up quick). Very dimensionaly stable due to small change between open and closed. Something for working tile, maybe?
    SS327 likes this.
  24. Jokester
    Jokester
    Thank you. THat makes sense!
    SS327 likes this.
  25. 210superair
    210superair
    from Michigan
    When I was a teenager me and my buddies worked at the local pizza joint. Whenever we hired a newb, we'd send them to pick up the 'bacon stretcher' at other restaurants. When they'd get back from the first place they'd of course say 'they didn't have a clue what I was talking about, they've never heard of a bacon stretcher', then we'd send um to the next place, until they figured it out, lol.
    SS327 and ekimneirbo like this.
  26. 210superair
    210superair
    from Michigan
    Mystery solved! We had our drain lines at work snaked by a plumbing company yesterday, and I showed the dude that tool, and he said that's a cleanout wrench for sure, one of a set of different sizes. Old though, and he had a kit like this, and said that's what they use all nowadays...
    ekimneirbo likes this.
