Hot Rods What is this tool ?
Discussion in 'The Hokey Ass Message Board' started by edcodesign, Sep 10, 2023.
  1. Budget36
    Budget36
    Yes. What I was speaking about. Just a “I need to know thing”:)
    Stogy and lothiandon1940 like this.
  2. Boggus Deal
    Boggus Deal
    That’s called a roll pin punch.
    Stogy likes this.
  3. edcodesign
    edcodesign
  4. lothiandon1940
    lothiandon1940
  5. Ned Ludd
    Ned Ludd
    I just found a nut splitter a**** the tools I inherited from my dad. It's over a year since he p***ed and I'm only getting to sorting out the tools now.
    Stogy likes this.
  6. Lone Star Mopar
    Lone Star Mopar
    Well you might as well throw out all your old junk wrenches seeing as this is "The only wrench you MAY ever need"... Great
    stuff
  7. Budget36
    Budget36
    Now those two I can clearly see would work for a bolt/nut with the 60 degree angles. That’s what had me scratching my head about the first pic from the OP. I was thinking it was for some special purpose.
  8. Stogy
    Stogy
    I many times see tools as aids...when you exhaust the standard fair you go for specialty tools which is how I look at this one...it may allow an install or removal to go ahead, even if all that's required is an 1/8 of a turn...
    I always say in those instances the tool many times earns it's stripes when this happens.
    Another thing this is more than just a nut turner...I can see it used in allen type applications as well...that gives more range for use...it could makes a great tool holder even for punches as long as the item being punched is requiring light blows...
    I see it even fitting non hex shaped tools...
    That all said I can't recall ever using one...even though I may have one...
    It's still amazing the stuff people design to help get the job done...
    down-the-road and lothiandon1940 like this.
  9. lothiandon1940
    lothiandon1940
    I use these all the time for taking the blades off my lawn tractor to sharpen them.
    Stogy and down-the-road like this.
  10. Budget36
    Budget36
    You folks recall those “”fits all bolt” tools with the flopping head? I forget what they were called, but the owner of the station I worked at had one hanging off the oil change drum.
    Was the go-to wrench for pan plugs.
    loudbang and Stogy like this.
  11. Stogy
    Stogy
    Yes you have refreshed my memory...and I've definately experienced the removal of those...just not to often hence my lapse...
    Boggus Deal and lothiandon1940 like this.
  12. Kevin Ardinger
    Kevin Ardinger
    Everyone where I work would call it a hammer
  13. lostone
    lostone
    from kansas
    Well the only question I have that hasn't been answered yet is....
    Can I still use it as a punch holder? It would get a whole lot more use as a holder vs. A wrench!
    Stogy likes this.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Try it.
    Stogy likes this.
  15. Marty Strode
    Marty Strode
  16. 51504bat
    51504bat
    Looks like you need to grind off the mushroom head on your punch. Just saying:cool: upload_2023-9-12_6-50-20.jpeg
    Never2low, BJR, Budget36 and 2 others like this.
  17. Illustrious Hector
    Illustrious Hector
    They tried to use it as a wrench instead of a chisel holder. Gotta love the many "last tool you'll ever need".
    51504bat likes this.
  18. Illustrious Hector
    Illustrious Hector
    That's so the vice grips don't slip off. not to mention the grooves left on the chisel shank.
  19. bchctybob
    bchctybob
    That looks like one of those “special“ tools that I look at, consider throwing it away, and then put it in the very back of the drawer, just in case.
    Budget36 likes this.
  20. edcodesign
    edcodesign
    bchctybob and Budget36 like this.
  21. Illustrious Hector
    Illustrious Hector
  22. el Scotto
    el Scotto
    from Tracy, CA
    I was going to say that but you BEAT me to it! :D
  23. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    And here I was thinking we found the tool to change the blinker fluid!
    :D
