What is this????????????
Discussion in 'The Hokey Ass Message Board' started by zoegrant, Feb 18, 2014.
  1. zoegrant
    zoegrant
    from CT
    Anyone know what this part is ???????? John in CT
  2. pinkynoegg
    pinkynoegg
    it looks like an upper bracket for air ride suspension
  3. squirrel
    Or a light mounting bracket. Might help if we knew what kind of cars you have pieces from
  4. bowie
    bowie
    Could also be a gauge or speedo mounting bracket?
  5. The37Kid
    The37Kid
    What size is it? Might be an instrument or gauge mount bracket. Bob
  6. It's use is limited only by your imagination! :D
  7. belair
    belair
    How long is a rope?
  8. I guess the answer is no.
  9. King Karl
    King Karl
    from N.C.
    Hate to be Mr. Obvious here but it's a bracket.
  10. Mr48chev
    Measurements and the thickness of the metal would go a long way towards helping someone figure out exactly what it is.
    Seeing the eye glasses in the first photo It's easy to tell that it isn't a bracket for an air bag but it is probably a retainer to go behind something and is held on with a nut or clip.
    If it is about 2 inches it probably goes on the back of a gauge to hold the gauge in the dash and it may go to a mini gauge.
  11. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    It's everything and anything you ever hoped it could be.
  12. looks like a metal bracket that is bent up on each end and has a hole drilled in the center, but I could be wrong....does not look too old.
  13. pinkynoegg
    pinkynoegg
    wow i was way off with the air bag bracket. I failed to see the size in comparison to the eye glasses.....Im with the others on a gauge bracket
  14. B Ramsey
    B Ramsey
    That's not a bracket. Its a tab.
  15. Larry W
    Larry W
    from kansas
    Not sure but I think I have the other side. $ 50.00 + s/h and you'll have a set..
  16. on the 58 caddy i restored, there was brackets like that that went under the fender to straddle the pinch weld seam in the fender. the bolt went through a clip, to hold the trim that was covering the seam, and between the seam in a notch to hold the clip.
  17. adam401
    adam401
    Weld on frame tab for rubber brake line to attach to steel line ?
  18. tpw35
    tpw35
    a picture of a pair of eye glasses, a bracket, a pencil and a rubber band.
  19. hotrod1948
    hotrod1948
    from Milton, WI
    I suggest it is a piece of metal painted black.
  20. traffic61
    traffic61
    from Owasso, OK
    Alex, I'm going to go with "What is a stamped steel bracket."
  21. Atwater Mike
    Atwater Mike
    The HAMB:
    Last stop for I.D. of misc. free parts destined for the 'BAY!
  22. choppednslammed
    choppednslammed
    I'm surprised no one asked how to wash it ...Jim
  23. Jokester
    Jokester
    No, How Long is a chinaman.
    I don't know what the part is, but it looks like a good one.
    .bjb
  24. Saxxon
    Saxxon
    Going with .... Bracket
    No
    Wait....
  25. jimbanner
    jimbanner
    I'm with everyone else on this: bracket.
  26. Firecat7
    Firecat7
    certainly looks like an airbag bracket to go on top of the rearend housing. good luck.:confused:
  27. prpmmp
    prpmmp
    It was a Toyota before the crusher!! Now its just a cheap bracket! Pete
  28. sawbuck
    sawbuck
    from 06492 ct
    ya but whats it worth ?
  29. seb fontana
    seb fontana
    from ct
    Looks like a rear spring front mount..
  30. zoegrant
    zoegrant
    from CT
    I believe it is a bracket to something on either a 56 T-Bird or a 56 Victoria.The measurements are ..2 1/2' long...tabs are 1" tall...widest part is 1 1/2"
    I`m stumped.....John in CT
