Projects what is your winter project?
Discussion in 'The Hokey Ass Message Board' started by 77salon, Nov 22, 2011.
  1. Boeing Bomber
    Boeing Bomber
    Finish my '66 bug so I can get my '41 Fordor in the shop.
    tear into the front end to replace the 4lug rotors with 5 lug Chev rotors so I can put on matching wheels. replace the front coil springs while I'm at it. (needs to come up a bit). then change the electric fuel pump from a puller, to a pusher. remove, clean, and seal the gas tank, and have several cold ones.
  2. tedster
    tedster
    Same as my summer project.
  3. 2935ford
    2935ford
    Tidy up my '28 Tudor odds and ends and complete my '29 Roadster AV8.
  4. OL 55
    OL 55
    Next year (2012) I'll have owned this thing for 40 years. Maybe I'll see if I can't get it going again!
  5. 76cam
    76cam
    My 30 model a and a 48 ford pu.If im lucky.
  6. 32fordroadster
    32fordroadster
    from Wisconsin
    After spending the last 10 years building my coupe and roadster, I am finally going to pick up my tools and clean up the shop so that if i do start another project, I can actually find what I am looking for!
  7. pumpman
    pumpman
    Try to finish last winter projects!
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    Time to get crackin' here in Arizona I will be working on insulating the interior of my '54 and installing the seats,console and headliner.Hard to get much done in the summer with 100+ degree temps you need oven mitts to even touch the car.
  9. todztoyz
    todztoyz
    Rewire the '57 and continue work on the '51.
      426 KB
      429.6 KB
  10. Floor boards in my 50. I'm all ready for engine/****** swap. But I need somewhere to sit as I cannot levitate yet.
  11. StLouisSled
    StLouisSled
    Gonna start my 51 Olds Super 88 club coupe project...car has been waiting 13 years for some TLC.
  12. chappys4life
    chappys4life
    from Austin, TX
    Mine is to work on my metalworking and welding skills . New to both so figure its a good plan of attack.
  13. BenDaPirate
    BenDaPirate
    Rewire entire car, driveline tunnel, motor rebuild/paint, interior.
  14. Looks like my summer project has turned into my winter project. I am still trying to wrap up the piddly ****. I hope the weather holds so it can be my winter driver. :eek:
    So as of now my winter project is my Willys truck, but if I get it sorted out in the next week or so I can jump back on my Stude project. That is my scheduled winter project.
  15. drfreeze
    drfreeze
    i'm restarting the fire under my *** to get the coupe going again >>>> stay tuned !
  16. mediumriser
    mediumriser
    from Ohio
    Bought 32' rails pinched for a model a. Got the front end, rear end, Yblock with a 3 duece set-up and a 4spd. Gonna start putting a ch***is togehter and search for a 28-29 coupe in the spring.
  17. Snafu
    Snafu
    OT but its a project I am working on this winter. Getting the car ready for next season. Need to strip the car and check it for cracks. Pull the caps off and look at the main bearings. Lots of work and a short time to do it.
  18. rustang
    rustang
    I'd like to get the ch***is completed on my '38 Chev pickup....I have the rear-end in with new springs and the front straight axle in with the new spindles, rotors, springs and mounts...... next I will be on to boxing sections of the frame and mounting the 327 and TH350...... then I will be pulling the 327 down to freshen up.... mount the steering box....I started a month ago, and may be ahead of my schedule at this point.. :)
    Tom
  19. gasolinescream
    gasolinescream
    I had the last ride in my car this weekend and it's now in the garage, so the winter project has started. My car's getting a few mods here and there. Grills made up, shiny bumpers, carpet set, new wheels/ WWW, a few things shaved off and tidy some paint and a few rust spots coming through. Biggest mod will be lowering, nice healthy drop with the **** dragging a little. Can't wait and number 1 on the list but also the most expensive so i'll carry on with the labouring jobs until i can order my shocks, coils and full polybush kit. My little caravan will be getting a makeover to match the car aswell. Plenty to do and looking forward to it.
  20. 48FordFanatic
    48FordFanatic
    from Maine
    Well, I just sat down from spending an hour on my Kubota clearing a foot of snow from the yard. So I'm thinkin my Winter project will be finding a place to buy in Florida, SC or NC.
  21. Starting work on my 49 Chevy pickup...strip it down clean the ch***is up, dropped I beam up front drop the back and rebuilt borg warner 9 bolt rear end. Get the 383 built and 700r4 all sorted. WWW on steelies....hopefully!
  22. droplord49
    droplord49
    from Bryan, Tx
    Gotta do a few suspension upgrades/al***ude adjustment and wheel/tire swap on my 53 Belair. Also going to upgrade my old lady's 65 Mustang to power disc brakes.
  23. 77salon
    77salon
    from RI
    sounds like some good projects you guys have.keep them comming
  24. yamadafacka
    yamadafacka
    getting this thing to roller status.
  25. 41 C28
    41 C28
    Things to do this winter are; replace windshield rubber and gl*** in my Dodge and maybe repaint my roadster.
  26. BAD PENNY
    BAD PENNY
    from mass
    Started my/our ( brother and I) winter project last night. Changing to a 4-speed muncie with pedals. Dropped axle w/ hair pins, steering box, brakes, Lime works column and maybe an engine rebuild...
  27. patrick66
    patrick66
    HAMB-friendly projects are the following:
    1) If I keep the '47 Hudson, I'll be pulling the engine and getting the '69 Dodge 440 ready to install, and go from that point...
    2) Just picked up a teardrop camper from a fellow HAMBer, so it is going to get fixed up with a new door, some skin work, and a all-new interior to replace the big, open space inside of it now! Finally found a home for the two Crestliner 15" wheels I've had for 20+ years!
    Non-HAMB projects:
    3) Convert my '71 Travelall to 4x4 with all factory parts, including a disc-brake Dana 44 front axle!
    4) Rear springs, minor wiring issues and a gas tank replacement on my '66 Dodge.
    5) Finish the X-body Buick interior replacement and sound system install.
    Now, as long as it remains above 20 degrees F in the shop, I'm set to be busy all Winter long! Fun fun!
  28. HotRodHighley
    HotRodHighley
    from cincy, oh
    Work on the 30 sedan and hope to have on road by spring, Build my frame for the coupe.
  29. bcook07
    bcook07
    from Illinois
    My project is to find a job so I can have money to work on my f100's or my mustang this winter. (if i find a job I am gonna start looking for a house too)
  30. OoltewahSpeedShop
    OoltewahSpeedShop
    What he said....
