What kind of battery do you run? Location etc.
Discussion in 'The Hokey Ass Message Board' started by clockwork31, Nov 21, 2011.
  1. miraclepieco
    miraclepieco
    Model A's typically have lots of room under the floor directly under the p***enger seat. Here's a battery box I built from some s**** bed frame.
    I wouldn't mount a battery in the p***enger compartment or on the firewall (inside or out); you'll need all the room available in those areas for other components, ie wiring, coil, heater and hoses, etc. Plus, batteries are always better hidden. Under the p***enger seat is wide open and you can run a big, and cheap, battery without paying through the **** for one of those street rodder special batteries.
  2. Muttley
    Muttley
    I have an Optima mounted in the trunk of my Comet.
  3. clockwork31
    clockwork31
    I forgot to mention that mine has no fenders/running board, that's why a normal size battery is a bit tricky if I decide to put it under the floor, it woudn't be hidden...
    If I was running fenders that would be the right place.
  4. shoprat
    shoprat
    from Orange, CA
    Duralast. Had one last for 10 yrs.
  5. I can verify that Interstate and Sears batteries are the same.
    Back in the early 80's I was a mechanic for Sears. We got a load of new batteries and I went into our battery room to take inventory. When I opened the door everything was green. I ask my manager if Sears changed the color of their batteries. We went back to the battery room together and that's when we both noticed that they were all Interstate batteries. The dumb*** delivery driver unloaded the wrong batteries.
  6. bulletproof1
    bulletproof1
    from tulsa okla
    in my car i installed it in the trunk right above the rear axle...napa battery
  7. fleetside66
    fleetside66
    I've got a $50 Sears battery in mine, mounted in my first official toolbox. One thing you should be aware of is proper ventilation. You can see the two large holes on the side of the tool box, which is now covered with a louvered plate to keep the rain out.
  8. hotrod_32
    hotrod_32
    Optima red top(8 years) in the trunk.
  9. hotrod_32
    hotrod_32
    A look
  10. josh highley
    josh highley
    I have been running Honda batteries. Group 51 can be bought anywhere batteries are sold for about $60-70. They are small and it has no problem starting a stock small block chevy. As long as you don't have a ton of compression, you should not have a problem with one. Hell my coupe starts better than my 03 gmc sierra.
  11. 40FordGuy
    40FordGuy
    Haven't heard of "Odessy" brand,...Where are they sold ?
    4TTRUK
  12. Abrasive Trader
    Abrasive Trader
    from Orange CA
    I run an optima. Expensive but have a warranty and its mounted on the floor.
    Some guys have really good luck with optima, other said they don't work outta the box sometimes:(
  13. dutch rudder
    dutch rudder
    from houston
    Optimas USED to be THE battery to get. 10 years ago, they were a premium battery that would last dang near forever. over the last couple years though, Optima's are JUNK. their build quality has gone to **** since they moved their operation to mexico. i cant tell you how many i have seen fail, and personally i have had 3 fail in the last 2 years.
    I personally like interstate, or odessy's.. then again, now that AGM' batteries are getting cheaper (you can get them now at vatozone or whathaveyou), they have become my new favorite over wetcell's.
    AGM's are TOUGH batteries. same technology that an optima has, but not paying for a name. take your pick- they all will die sooner than later. me? i normally get the cheapest with the longest free warranty. pro-rate is ok, but sure beats forkin out cash.
