Hi Guys, I thought I would buy a new modern solid-state type cutout for my generator on the Model A from the middle of -28. But! I was surprised that my generator didn't looked like a normal Model A generator. I don't why I haven't noticed this before. I'm running the original 6 volt positive ground system. I have no idea where this generator is coming from. What kind of generator is this? See the attached pics. Thanks! //Andy
They made two kinds of the early power house generators. A 3 brush & a 5 brush. The 5 brush is the better of the two. If that's an original shroud on the radiator it's worth some good money to a restorer.
Thanks guys, I know that the generator is working because it's charging the battery but I don't know if it's over- or undercharging yet. The Am-meter is not stable at all so it's hard to see what the Amps is. I have to have a look on it if it's 3 or 5 brush generator. But can I still mount a solid state cutout? The fan shroud is hopefully original and I will try ro restore the car in the future. The starter is also one of the early ones because it's shaft is only 1/2" or something. Thanks again!
The powerhouse generators were used until Mid-29. The cutouts should be the same, 6V is 6V, and I think Ford used the same ones for YEARS as far as bolt patterns are concerned.
