What linkage to use??
Discussion in 'The Hokey Ass Message Board' started by ifihadthetime, Feb 7, 2008.
  1. ifihadthetime
    ifihadthetime
    What linkage would you guys recommend,i am putting a pair of 97 s
    on a Tattersfield intake,59ab with a max1 cam.Should i use solid,or progressive?
    I had read somewhere that i should use progressive so when you open the throttle you do not loose all of the vacuum at one time.
    Also does the tattersfield share runners to the front and rear,so if i did run progressive it wouldn`t starve the rear cyl.
    Thanks Randy
  2. dickster27
    dickster27
    from Texas
    Take a piece of advise here Randy, you will be much happier with straight linkage as it will give you everything you want but much easier to dial in on your flatty.
  3. strombergs97
    strombergs97
    You tell him dickster27..Make it easy and run right.
    Duane.
  4. Straight linkage for sure.
    Matt
  5. ifihadthetime
    ifihadthetime
    Thanks guys for the advise,guess i will be running them together.. Randy
