What m/c for '32 with Wilwood discs and drums?
Discussion in 'The Hokey Ass Message Board' started by Cool32, Jul 7, 2006.
  1. Cool32
    Cool32
    from Texas
    I have a '32 with a TCI dropped axle. It has Wilwood calipers in the front and drums in the rear. I'd like to pick up a manual m/c locally, but can't find the info to pick an application. Anyone know what m/c to ask for at the parts store?
  2. Cool32
    Cool32
    from Texas
    Oh yeah, don't let the Wilwood stuff scare you away. It just happens to have the funky front calipers until I get around to swapping in the Buick finned drums.
  3. 7/8" bore Torino M/C works well with the 68-70 Mustang front discs and 68 Merc wagon drum brakes on my 32 roadster.
    EZ pedal and good braking.
    The Torino M/C has the brake fittings/lines pointing at the left frame rail when the M/C is in the usual hot rod position . . . which is to say, pushrod at the front.
    If having the brake fittings/lines pointing at the driveshaft works for you, a 68 or so 7/8" bore Mustang M/C will work just as well.
    This info pertains to a US left side drive car as shown in the pic.
  4. Cool32
    Cool32
    from Texas
    The Wilwood calipers have 4 pistons, so I wonder if that M/C will still work.
  5. The Mustang caliper has a fairly large single piston.
    How big are the Wilwood pistons?
    And how big an M/C does Wilwood recommend?
    You're gonna do Buick drums anyway, so why not gear the M/C toward the drums and if it necessary, suffer through the disc brakes for a while if the M/C is not quite right.
    Most hot rod brake pedal applications call for a 6 or 7-1 ratio.
    If Wilwood calls for a similar pedal ratio and their M/C is about the same bore the Torino/Mustang M/C's are probably a workable deal with the calipers.
    The FoMoCo Mustang style M/C's come in 1" and 1 1/8" bores and there may be a 15/16" bore available as well.
    Fwiw, pedal effort on my non-boosted 32 is about the same as it is on a non-boosted Pinto.
