what M/C to run F100 brakes Model A
Discussion in 'The Hokey Ass Message Board' started by Fry, Sep 10, 2005.
  1. Fry
    Fry
    from SK, Canada
    Been researching about brakes lots lately and read the tech post about using F100 brake shoes and hardware with 53-56 drums and backing plates. This is the setup I am going to use on the front and for the rear I have a 9" out of a 67 pickup. What should I look for in a master cylinder?
    Thanks
  2. my `28 tudor with f-100 front brakes and a maverick 8" rear end has a `67 mustang 1" bore drum/drum master cylinder....they work great
  3. 29SX276
    29SX276
    Fry;Your question couldn't come at a better time;I'm on the search for a M/C too.I was thinking of using a Ford pickup unit.I've got F-100 brakes on the front and a 9" Ford pickup rear end.So the Mustang unit might be the ticket;how pricey are these things?I'll have research the Ford pickup M/C's as to bore sizes etc.Anyone got any info on these things?
  4. QQMOON
    QQMOON
    I have F100 front and rear.... and a 1 bore m/c the front brakes are boosted only and it stops real good its got to stop good any one can make them go fast you also got to stop fast!!!
  5. Flat Ernie
    Flat Ernie
    Tech Editor
    Cheap! ~$20 or so for re-man w/core - ~$70 for new
  6. I run a fruit jar, Mustang style (EEEK) SINGLE resivoir on mine... works great.
    Sam.
  7. Fry
    Fry
    from SK, Canada
    so this would be a manual setup right with no booster or anything. I don't know mustangs or much about drum brakes either lol.
    I have my frame pretty much done and am starting on the floor pretty quickly so I want to make sure I have room for the m/c.
    Thanks for all the replys.
  8. Kruzer63
    Kruzer63
    Well what we have always run with drum brakes is a dual resovoir 67-72 Mustang master cylinder. Cougars have a similar one that works well too. When you check on it you can actually get different ones with inlets on either side depending on the year, and that can help depending on your space limitations as well.
  9. yes, use one for manual brakes and drums front and rear
    Napa #101488 is one that i have used.....i have also used carquest 20-1485
  10. Fry
    Fry
    from SK, Canada
    sweet, thanks for the info guys
  11. Fry
    Fry
    from SK, Canada
    This is an old post but relivant to my situation, I needed a master cylinder to make sure I leave room in my floor bracing that I'm currently working on, anyway I picked up the mustang one mentioned by 36-3window but it didn't come with a rod that I need. Napa said they couldn't get one, any thoughts on where I could?
  12. Fry
    Fry
    from SK, Canada
    Looks like 10-1488 is for the one that doesn't have the rod and
    10-1485 is for the one with. All of $1 difference, much cheaper than the $50 wanted on mustang restorer sites for just the rod.
  13. Kruzer63
    Kruzer63
    I always make my own rod, i have never bought one, i make em outta 3/8 CR round bar, round the end off that goes in the master so it doesnt chew it up, and thread the other end for a Rod end to hook on and done.
  14. gregg
    gregg
    from Fulton IL
  15. tommy
    tommy
    Sam you are such a daredevil!:D
  16. Fry
    Fry
    from SK, Canada
    what about the lock on the inside? Don't worry about that? I can't see really needing it.
    Thanks
