What Main Bearings do i use ?
Discussion in 'The Hokey Ass Message Board' started by ifihadthetime, Jan 6, 2008.
  1. ifihadthetime
    ifihadthetime
    I am putting a 49 up merc crank in my 1948,what main brgs do i use? i have a set(must be from a 49) because the thrust bearing will not fit the block,the are federal mogul 646m. i guess that i have to use main bearings from a 1948 , and they will work with to 49 crank??Thanks Randy
  2. Bruce Lancaster
    Bruce Lancaster
    Use the '48 mains, use rod bearings to suit whichever rods you have.
  3. R Pope
    R Pope
    Don't forget to check for clearances, 239 blocks need to be "opened up" a bit to fit a Merc crank. Also the oil pickup tube will hit the crank.
