Art & Inspiration What makes your car or cars unique?
Discussion in 'The Hokey Ass Message Board' started by KoolKat-57, Jul 17, 2019.
  1. DDDenny
    The louvered hood on my 66 Suburban.
    Notice the two outer sections have standard louvers (outies) while the two inner sets of louvers are inverted.
    jet996, lostn51, Chucky and 2 others like this.
  2. DDDenny
    There are a handful of unique (handmade) items on my roadster but the rearend is something many people might not recognize.
    Kind of big and not too pretty by some standards, this is a 1957 Ford F-100 half ton rearend housing.
  3. choptop4
    choptop4
    Been in the family for 69 years. FB_IMG_1635717301284.jpg FB_IMG_1661786563537.jpg
    jet996, BigRRR, Ziggster and 10 others like this.
  4. hotrodjack33
    hotrodjack33
    Another unique detail on my Cabriolet are the jewels.
    I drilled the '49 Ford hubcaps and added blue-dots with green jewels in them.
    I ground down a green jewel to fit the crank hole in the grille.
    I made green jewel bolt covers for the bumper iron bolts.
    With a name like "Irish Jack Murphy"...well, that should explain a lot...:D.
    jet996, Dave Mc and hfh like this.
  5. 49ratfink
    49ratfink
    Chrysler made my Dodge unique. I didn't have to do a thing.
    jet996, Ziggster, alanp561 and 8 others like this.
  6. Boneyard51
    Boneyard51
    They only made my car for one year!
    Bones
    jet996, alanp561, Dave Mc and 2 others like this.
  7. MCjim
    MCjim
    from soCal
    '58 Thunderbird grille
    jet996, BigRRR, Stan Back and 10 others like this.
  8. Stan Back
    Stan Back
    They only made 57 Chevys for one year, too.
  9. topher5150
    topher5150
    I think all the old 40s-50s parts...Buick head lights, Mercury tail lights, Plymouth bumpers, Olds hub caps, shoe box ford trim, and Nash rear bumper guard and a few other kustom goodies.
    jet996 and Dave Mc like this.
  10. jnaki
    jnaki
    Down tube exhaust outlets
    Hello,
    From the time my brother had our local welding/muffler shop install some down tubes for cut outs, the job of opening and closing them was left to “guess who,” when I was old enough. But until I was, my brother did the same thing when the chips were down. There were many teenagers during the 1956-65 time period in our local Bixby Knolls area that had down tube exhaust cut outs.
    In his days of driving and racing the 1958 Impala, there were many times that he would crawl under the car to open the down tube cut outs. He had to unbolt one, loosen the other and move the cap over to one side. Then tighten the remaining nut so as not to lose any during the upcoming encounter. This was a standard operating procedure for most teenagers that had any kind of exhaust cut outs back then. It was a h***le, but it was a fix-it ticket at the very least from the CHP.
    With the next generation of teenagers taking over the cruising hot rod scene, changes had to be made. One time on Cherry Avenue, the CHP broke up a race and chased a lot of teenagers all over the area. Luckily, my friend lived just around the block from the cemetery and told me to pull into the cul-de-sac near a low growing tree. He knew this spot was perfect for hiding. We had to jump out and cap up the exhaust cut out caps in case we were given the once over from the chasing CHP cruiser. Using an open end wrench or box wrench was not the fastest, but the only way to get the caps back in place, in silence.
    We obviously were on our backs, upside down, removing one nut, loosening the other, swinging the cap over, installing the loose nut and tightening both as if it was never open. It was time consuming and exciting at the same time.
    Downward exhaust outlet flange with wingnuts for quick opening/closing and removal.
    Then one day hanging around my friend’s house, we figured out a way to make the opening and closing of the down tube exhaust cut outs so much easier and faster. A small slit on one side of the exhaust cap end fitting. Wingnuts (with Loc***e or some solution) instead of an ordinary nuts. That way, a small tap is all that is necessary to tighten and loosen the cap for that extra power and sound. The reverse was easy, as the cap just swings back over the opening and the wingnut gets the tightening. Problem solved.
    The nut was now permanently attached to the cap with a wingnut. When the wingnuts were loosened, the cap easily slid out and over to open the exhaust opening. The wing nut was easier to tighten and keep in place. Even a small rock could tighten the wing…
    Before we started using blue Loc-***e, several of the wing nuts came loose and fell off, creating a jiggling metal on metal sound. The cap was loose and one remaining wing nut was keeping the whole thing from falling completely off.
    Jnaki
    So, the process is not just a waste of time, being macho or anything, but just something that was necessary for added sound and power. Opening the side or down tube exhaust cut outs is/was a standard procedure. But, crawling under the car to reach the down tube was a chore. The side cut outs could easily be capped up in a flash. Stop, flip, tighten the wing nut… silence is golden …
    From the 1959-60 standard exhaust cut outs to the electric cut outs is a long way apart. If we had those devices, it would have made it simple. But, not the true teenage ideas that made it fun and exciting while experiencing growing up. Cuts outs are Traditional, but electric cut outs are way beyond the timeline cut off dates. YRMV
    BigRRR and Dave Mc like this.
  11. lostn51
    lostn51
    from Tennessee
    The only claim to fame for this one is that it was bought new by my great grandfather and has always been in the family. IMG_2546.jpeg IMG_2568.jpeg
    SS327, jet996, BigRRR and 5 others like this.
  12. lostn51
    lostn51
    from Tennessee
    My woody was in the movie “Walk the Line” and was driven by Joaquin Phoenix with Reese Withers**** climbing all over the place it :D IMG_2491.jpeg
    SS327, jet996, BigRRR and 9 others like this.
  13. goldmountain
    goldmountain
    Glove box light. Always put them in my cars. Don't know why. Don't have gloves; no one ever looks there but somehow the car isn't done without them.
    SS327, jet996, Stan Back and 3 others like this.
  14. deucemac
    deucemac
    What would make my avatar roadster unique would be the transmission. People ask what transmission I am running and I reply, " A 76 AMC Pacer ". I get a lot of strange looks when I say that. But it is true. When I was building the car, I decided that I wanted to use a Ford full syncro 3 speed and an overdrive. I had worked for the Border Patrol as a mechanic and we had Jeep Cherokees with Ford full syncro 3 speed trans and a top shifter. I wanted an overdrive also, so I cared Gordon at Stick Only in the San Fernando Valley and asked him which Fords used the full syncro 3 speed with an overdrive. He told me that they never did but AMC did on 75-77 Pacers, Gremlins, Hornets. They were using the trans throughout there line and added a Lay**** overdrive to those three models. We'll, I found a perfect example in Fresno and brought it home, took it apart and everything was great. I put a small parts kit in it and then put it in my roadster. I converted it to a Jeep top cover and bolted a 36 Ford hand brake on the side. It works perfectly even after 15 years of service. The old time look on the floor of my roadster hides all the later model parts. I can get aĺl rebuild parts for the trans and overdrive, but if I ever break the factory AMC adapter, I will be in trouble! After all the perfect service I have gotten out of the combination, I feel pretty safe with it. The best part is to be at a show and someone will come up and inspect my hemi, look inside the ****pit, and then ask what trans I am running. It's fun to watch the look on their face when I say "a 76 AMC Pacer transmission". After they shake their heads, I explain the generic history of the parts and they all seem to enjoy my original answer. 40+ thousand miles on the combo and no problems. Speed shifting is not possible with the Jeep top cover, but other than that, it's ideal!
    cfmvw, jet996, 49ratfink and 5 others like this.
  15. Slopok
    Slopok
    The Flames, if it weren't for them, it would be just another black Merc!
    After owning it for 41 years, it is now owned by @CHITOWN 29A and driven way more than I was ever able to even to work, weather permitting! Couldn't have gone to a better caretaker.
  16. qicvick
    qicvick
    Mine is unique mainly that it was my first car I got in Oct of 1971 so I’ve owned it 54 years this month, over the years I replaced the Yblock with 351w in the 80’s, added AC, PS, Front Disc PB, C4, tilt Wheel,8 inch rearend, Holly sniper EFI, shaved hood and doors…. To be continued! IMG_2248.jpeg DDA822F0-1955-40DF-8A01-0E6C4AF3DC6A2011-11-12_19-04-45_000.jpeg
  17. Splitbudaba
    Splitbudaba
    My coupe has some rare SBC valve covers! I was told they were only made one year, 62. No triangle on the logo pad, front or back!
    enloe, loudbang, BigRRR and 1 other person like this.
  18. Bandit Billy
    Bandit Billy
    Leather wire ties. :cool: Neither traditional nor modern, sorta like me.
    Brown on the roadster
    Black on the truck
    Comes in handy having a seamstress for a daughter.
  19. jimmy six
    jimmy six
    enloe and Sky Six like this.
  20. Ziggster
    Ziggster
    Don’t think anyone has ever done an exhaust like this on a flathead. Haha! Rear mounted rad is also a little unique.
    SS327, jet996 and enloe like this.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    was one of the "sweet 16" original Hotwheels in 1967 and was an AMT model kit dream11.jpg dream22.JPG dream11111.PNG dreamrod.jpg dreamrod222.JPG dreamrodautorama.jpg
  22. enloe
    enloe
    from east , tn.
  23. rockable
    rockable
  24. nochop
    nochop
    from norcal
    1, it’s my dads , 2, I’ve been playing with in it since I was 5 (I’m 70), the Rocket, the dash, the steering wheel and column drop, and possibly 100 more things IMG_7880.jpeg IMG_7877.jpeg IMG_7765.jpeg IMG_8148.jpeg IMG_7374.jpeg
    Splitbudaba, enloe, Ziggster and 7 others like this.
  25. '29 Gizmo
    '29 Gizmo
    from UK
    When I bought my Model A a previous owner had rough cut a piece of 1/4" steel plate to make a light board for the back whilst it was a work truck. Looks like it had been done decades ago. I decided to keep that theme as part of its story but restyled it a bit. I even kept the same lights, just made bezels for them. I'm happy with the result.
    Screenshot_20251027_065627_Gallery.jpg Screenshot_20251027_065535_Gallery.jpg
  26. sweetdick2
    sweetdick2
    from new jersey
    enloe, Ziggster, jet996 and 2 others like this.
  27. jet996
    jet996
    from WY
    enloe and SS327 like this.
  28. seb fontana
    seb fontana
    from ct
