1952-59 Ford What master cylinder do you have?
Discussion in 'Off Topic Hot Rods & Customs' started by 53vicky, Apr 4, 2012.
  1. 53vicky
    53vicky
    I am have the original master cylinder on my 53 and i have been considering putting a dual master cylinder on just to be extra safe. Are there any that mount right in?
    I am not worried about the lines because when they chevy engine was put in my car back in the 60s the brake lines were redone and it would be easy to put this new master in, just wondering about mounting it to the fire wall...
    what do you guys recommend?
  2. Ole don
    Ole don
    Torino drum-drum fits. They fit in the bottom two holes, but you need to put bolts and nuts in the top two holes because the top bolts hold on a bracket under the dash. I also like to weld up a little bracket to mount a plunger type brake light switch that the pedal arm pushes on to get rid of the trouble prone stock brake light switch
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. 53vicky
    53vicky
  5. Rayj53
    Rayj53
  6. 53vicky
    53vicky
    thanks RayJ53
