What Master Cylinder to use?
Discussion in 'The Hokey Ass Message Board' started by CURIOUS RASH, May 21, 2012.
  1. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    59 El Camino, front disk, rear drum, no booster.
    I hear some Vettes were spawned this way but I am no subject matter expert on Vette's, or anything else for that matter.
    Trying to get this turd to the HAMB Drags this year..
  2. 50shoe
    50shoe
    not sure on the vettes, but I know late 60s mustang mc can work well for this kind of thing.
  3. Rashy, what Exactly are the front calipers and the rear wheel cylinders?, makes a difference.
  4. tommyd
    tommyd
    from South Indy
    We used the vette M/C on my son Camaro drag car. It has disc /drum set up and it works great. Stops good even on tracks with a short shut down area.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ask for 1970 Vette with manual brakes.
  6. How long is a rope?
    How high is a tree?
    How much beer can the Vagabonds drink? Ok, that one may have an answer.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Judging by your answers, alot has been consumed ;):D
  8. Not yet but you don't get it I see? Rashy asked the same open answered question that CAN NOT be answered without more info. We can guess, we can get close, we can get lucky. I like to do it right from the start.
    The answer to my last question was "all of it."
  9. DD COOPMAN
    DD COOPMAN
    Vettes THRU '64 all had drums. '65s came standard with 4-wheel discs, although you could opt for ALL drums and receive a credit. From then on, 4-wheel discs were standard. What you're probably thinking about is that the 4-wheel discs COULD be ordered WITHOUT power. I had a '69 built without power. It would stop, but ya had to put a little effort into serious stopping. 1" bore M/C if I remember correctly. DD
  10. and what pedal ratio do you have? 6:1 or 7:1
    as a base line I expect you'll need 1" minimum, with an expected 1 1/8" and a longer pedal ratio preffered since you're not going with a booster.
    Cheers,
    Drewfus:)
  11. CURIOUS RASH
    CURIOUS RASH
    Its a 59 El Camino, with 59 El Camino rear wheel cylinders, new, and disk conversion with 78-85 Monte calipers.
    The pedal is still in the stock hole so whatever ratio that is is what it is set at.
  12. Rear stock are 1" cylinders used a 1" MC
    Monte was a couple sizes 2/12" front and 2 15/16s" MC was anywhere from 7/8" to 1 1/8" these are all listed as boosted. Are you manual?
  13. 53chieftian
    53chieftian
    GM stuff is pretty simple and standard across the board. I would simply try say a 70 Chevelle with front disc and no booster or something similar. Worst case it doesn't work right and I'm sure you have a friend with a Chevelle that needs a master!
  14. friends don't let friends drive Chevelles!
  15. wildearp
    wildearp
    from tucson, az
  16. Chucky
    Chucky
  17. Process of elimination (cross referenced from the Elco to the other various parts) in my Wagner book leads me to a 78-80 Monte Carlo manual MC Wagner # F101252. It is actually a 7/8" MC. A close start if nothing else. There are a couple sizes above and below that if it need fine tuning.
    You could match the Monte setup perfectly by using the rear WCs off the same car. 3/4" Wagner # F110260 right AND left
