what material for a louver die?
Discussion in 'The Hokey Ass Message Board' started by brady1929, Jul 12, 2008.
  1. brady1929
    brady1929
    hello,
    for those of you who have made your own louver dies, what material did you make the louver dies out of? hardness? ect. thanks
  2. sliderule67
    sliderule67
    from Houston
    Not exactly my specialty, but I'd start look at air hardening tool steels. Maybe we've got a tool and die man in the HAMB.....slide
  3. RoadkillCustoms
    RoadkillCustoms
    from Mesa, AZ
  4. brady1929
    brady1929
    thanks for the info. would someone be willing to send me a profile of their 3 inch louver? just use a piece of poster board. i would be willing to pay for shipping.
    thanks
  5. 4-pot
    4-pot
    I used S-7 for mine just because I had a lot of it lying around. Most any tool steel properly hardened should work.
    SDS likes this.
  6. Vance
    Vance
    from N/A
    The guy who punched my louvers made his own out of 4140 and it's held up for years. In 30 years, he said he's only replaces it once and he's busy guy.
    I'll get some real close-up pix tonight of my louvered trunk lid if you want.
    Vance
  7. zman
    zman
    from Garner, NC
    I can trace mine, scan it, and email it to ya.
  8. diggers4life
    diggers4life
    If you can get a chunk cheap, my first choice would be either M-2 or D-2. Otherwise, A-2, S-7 or O-1 would be good choices. They will probably be a little cheaper, definetly easier to machine, but may not hold up quite as well as the M-2 or D-2.
  9. jusjunk
    jusjunk
    from Michigan
    I made one years ago then sold it and i just used oil hard tool steel and it was fine.. But i wasnt doing production either.I hardened it to 56/58 rockwell and it was fine for me
    Dave
  10. brady1929
    brady1929
  11. 55 dude
    55 dude
  12. skidsteer
    skidsteer
    contact homeadehardtop57. I believe he has a 3" press.
  13. NaKpinstriper
    NaKpinstriper
    Make sure you have the capabilities to heat treat the type of tool steel you choose. This is why an oil hardend tool steel would be the easiest. It can be done with a torch, you can even do the drawback with a torch.
  14. Homemade44
    Homemade44
    Brady, The male die on mine is nothing but hot roll shaped to the profile that I want. The cutting edge of the female die is a piece of and old shear blade, some tool steel, and the back of the female die is aluminum. I have not had a problem with this arrangement even punching 16 gage. Have made dies in many different sizes and shapes. Tool steel would probably last much longer but I am not in the business of punching louvers and haven't had a problem yet. The shape, profile of the louver, is what you want it to look like. I make most of mine with the rounded top, old school, and not like the ones made today that are flat on top.
    Joe Hartson
    NoelC likes this.
  15. alanp561
    alanp561
    Has anyone used mild steel to form the dies? My thinking is that if you form the male die undersized, then you build up the cutting edge with a hard facing impact rod such as Stoody 11172500. You could then grind it back to the desired profile and it should stay sharp for a long time. If the edge chipped, it should be a simple repair.
  16. NoelC
    NoelC
    Not those dies, but for other dies, yes. And while your plan is good in theory, going with a higher carbon material does also allow for simple tempering if you choose, or a harder material in general to begin with. Say a 4130 or a 4140. Equates to less work.
    That said and more worth saying, there is a lot of over thinking going on here. Take the material, even a 1030 mild steel can be enhanced with surface hardening to hold up well in home service.
    Being realistic, there is a big difference between 100 punches and 1,000 punches. How many will a guy really do?
    Oxy-acetylene, red hot, turn off the o2 and soot it up with carbon, do that a few time so it soaks in then quench in oil. You will be surprised at how hard the surface will get, and how well it will hold up.
    Also as you mentioned, mild steel is easily repaired.
  17. alanp561
    alanp561
    @NoelC, thanks for the reply and the information. Wasn't trying to overthink it, just trying to work with what I have on hand. I've got impact hard facing rod, ***orted axe heads, heavy plate and so on.
    High test 63 and NoelC like this.
  18. metlmunchr
    metlmunchr
    The hardfacing rod you called out should work okay. As welded hardness is Rc 52-58 and if it is subsequently water quenched from 1700*F it will give you Rc 56-60. 52 is somewhat low for a cutting edge, but most stuff like this tends to fall toward the middle of the specified range and Rc 56 or so should work fine. If it wears too quick you can always heat it up and water quench it to increase the hardness.
    Proper clearance between the punch and die at the shear edge is real important both for wear and for getting a good cut edge. For 16ga and lighter mild steel you'd want .006" clearance.
    alanp561 and NoelC like this.
  19. alanp561
    alanp561
    @metlmunchr , thanks for that info. I was curious about clearance. Would a light lubricant on the dies help?
  20. 38Chevy454
    38Chevy454
    That powder in the pics is just carbon powder, probably with something to help it stay stuck to the surface. It diffuses carbon into the surface, making it harder. Technical term is carburizing. Most commercial carburizing is done using a carbon rich gas environment in a furnace, but you can also surround the surface with carbon powder. It takes time and temp (higher is faster) to allow the carbon to diffuse into the steel surface. Really something that needs to be done in a controlled furnace, not a torch in the air. Note that the resulting higher carbon surface depth is not much, so too much final grinding or shaping to size will go through the layer.
    As an aside, nitriding is a similar surface hardening process where nitrogen is diffused into the surface. Except done at lower temps like 900-1000F, and the resulting surface depth is only 0.002-0.003 inch.
    alanp561 likes this.
  21. As I was reading the posts, I was thinking to myself, clearance is just as important as material. I use H-13 and a S-7 a lot and D-2, if you build in proper clearances and keep your tool well maintained, any of these materials once hardened should do you well.
  22. SDS
    SDS
    What he said - air hardening. Try A-2, it's easy to work with pre-harden. Make sure to thoroughly encomp*** it in foil (to prevent carburization and include some steel wool and paper in the bag.
  23. bobss396
    bobss396
