Technical What mirror is this.
Discussion in 'The Hokey Ass Message Board' started by Mitchell Rish, Mar 12, 2026.
  1. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I am trying locate a mirror like this one.
    I’ve never seen this in a tri five before. Someone educate me please. I have another pic from a 55 but it doesn’t look the same.
    AS always thanks ahead of time.
    chryslerfan55 and 51 mercules like this.
  2. Typical after market mirror. Can be mounted there or on the top edge of the door. Available many places.
    Ben
    Mitchell Rish and chryslerfan55 like this.
  3. '29 Gizmo
    '29 Gizmo
    from UK
  4. TCTND
    TCTND
    Those things ****.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I had to rotate this. I just stared at the photo not knowing what I was looking at. Some missed spelled NASA rocket did cross my mind for a second. :confused: :) IMG_5485.jpeg
  6. BJR
    BJR
    They work ok on the drivers side but not on the p***enger side.
    Mitchell Rish and little red 50 like this.
  7. Squablow
    Squablow
    The one in the old pic is an earlier design with a straight arm instead of the angled one. The angled one is designed to mount to the top of the door and hang down, the old ones were meant to mount down low on the door post (as shown) and also the arm was a bit longer. The angled ones were more for looks I think, the old straight/long arms afford a bit more adjustment and actually work better.
    This one is probably a better approximation of the one in the first photo.
    https://www.ebay.com/itm/1534597062...mqN3zhpEtsZbpA9wGVSzdGusQ=|tkp:Bk9SR9D3mbOcZw
    Mitchell Rish likes this.
  8. Mitchell Rish
    Mitchell Rish
    from Houston MS
    The pin strip goes around the mount. There are two holes. I guess I could fill the holes. And let it go.
  9. 325w
    325w
    GM offered a peep mirror. Seen on pickups. Found one inside a door I was removing parts from. It had GM logo. Only one I’ve ever touched.
  10. gene-koning
    gene-koning
    Add me to the list that says those mirrors ****. Those old 60s era door mirrors that screw into the top of the door would be much better mirrors, if you really want to use it as a mirror you can actually see something through.
    rod1 and Mitchell Rish like this.
  11. bill gruendeman
    bill gruendeman
    You can’t see much but, I can see enough. The p***enger side works well for backing out of the garage.
  12. Mitchell Rish
    Mitchell Rish
    from Houston MS
