Hot Rods what ohm rating sender?
Discussion in 'The Hokey Ass Message Board' started by silent rick, Apr 6, 2022.
  1. silent rick
    silent rick
    what ohm rating sender does one run with this early stewart warner gauge? i don't have one yet but am trying to decide if i want one. i have the matching oil pressure, temp, amp and vacuum gauges. i didn't need one at first because i was running a float style sight gauge on the tank.
    now that i'm sticking the tank inside the turtle deck, i need something visible from the driver's seat. the sending unit on the tanks i'm looking at are a modern 0-90 ohm. i know this gauge is hard to find, i know if i find one it's going to be pricey. if it won't even work with a 0-90 ohm sending unit, i might as well by a modern gauge and mount it in some out of the way location so it doesn't clash with the vintage stewart warner line up.
    or do i mount it with the other gauges with hopes of finding one and eventually swapping it out and change the sending unit in the tank?
  2. MARKDTN
    MARKDTN
    With todays fuels I would get an ISSPRO floatless sending unit regardless of what comes with the tank. They are available in all of the ohm ratings. SW was available at times in different ohm ratings, so I think the answer is "it depends". If there is no p/n or information on the gauge, you could get some cheap resistors and just try them out on the ground side until you find empty and full.
    silent rick likes this.
  3. pprather
    pprather
  4. Nailhead Jason
    Nailhead Jason
    I dont know the OHM rating for that gauge, but TANKS inc will sell you a universal sender in any ohm range needed.. I got one from them that works my stock 39 fuel gauge perfect.
    5window and silent rick like this.
  5. squirrel
    427 sleeper, pprather and silent rick like this.
  6. silent rick
    silent rick
    sounds like you guys want me to spend the money on the vintage stewart warner gauge.
    Paul and pprather like this.
  7. Dreddybear
    Dreddybear
    e1956v, silent rick and pprather like this.
  8. e1956v
    e1956v
    Alliance Vendor
    I couldn’t find the ohm listing but did find the fuel tank sender numbers that may be able to be cross referenced. BD5FBB89-15AB-4DB9-9C2C-3553C92015E1.jpeg 93930B61-478C-4E6B-AB31-03779EE4EC1A.jpeg 90376086-E4E3-4FD8-9515-707F47DFBE01.jpeg
    Cost on the 688-A gauge was a whopping $9.40
  9. 19Eddy30
    19Eddy30
    from VA
    To find the oms needed ,
    Could you use a Rotary ohms ( like a volume switch) bench testing ,Connect rotate to full , take a oms reading , then rotate to Empty,Take a reading , would that tell you the oms the gauge works on ? E -F
  10. squirrel
    Most volume controls are 0-10,000 Ohms, or more, which is kind of tricky to get adjusted to the low resistances that gauges use. A 300 ohm rheostat would probably work better. But I just use various resistors from my old resistor ***ortment when I need to test gauges.
  11. silent rick
    silent rick
    might end up trying this but dammit jim, you have to change your avatar. it looks like a guy i went to school with and i keep thinking, when did he join the hamb, he wasn't into cars
  12. silent rick
    silent rick
  13. squirrel
    yeah, the picture is from 1978, beginning of senior year in High School.
  14. silent rick
    silent rick
    i got you by a year, i graduated in 78
  15. Beanscoot
    Beanscoot
    Maybe some of you guys are envious of his thick, long locks of hair.
  16. brading
    brading
    This is how I checked my fuel gauge after following Dreddybear's post.
    bchctybob and e1956v like this.
  17. 1971BB427
    1971BB427
    from Oregon
    If you take a variable potentiometer and hook up a 12 v. battery to it and the gauge, you should be able to figure out what range it operates in, and also whether it's straight or reverse polarity. You can buy a 0-100 ohm pot at most electronic suppliers pretty cheap for testing.
    That's the same thing I do, but with a lower range potentiometer. You can also determine if it's reverse polarity or straight if you swap the leads from the battery.
  18. e1956v
    e1956v
    Alliance Vendor
    image.jpg After reading this thread I remembered the HAMB post from Dreddybear on the gauge tester he built. I had ordered everything I needed to build one but totally forgot about it.
    Luckily I found the parts and decided today was as good as ever to make it before I forgot again or lost the stuff all together. It works great. I was able to check the ohm range of this 1950 Chevrolet fuel gauge.
    I took a video by couldn’t figure out how to upload it.
    silent rick, pprather and Paul like this.
  19. squirrel
    Upload the video to youtube, then link it here with the "media" thingy.
  20. Paul
    Paul
    Editor
    Got this gizmo at a yard sale many moons ago ..
    Wonder if it could be made to do the job..
    PXL_20220407_171818816.jpg PXL_20220407_171847575.jpg PXL_20220407_171822520.jpg
  21. 5window
    5window
    Maybe a long shot, but could you send it to Tanks,Inc and ask then to match it to a sender? They're pretty good guys.
