what oil do you use
Discussion in 'The Hokey Ass Message Board' started by Jarred Hodges, Nov 28, 2009.
  1. Jarred Hodges
    Jarred Hodges
    I use castrol gtx 10w-40 in most of my vehicles
  2. i have Valvoline 10w-40 in both my `36 and `28 tudor....both with sbc's
  3. tfeverfred
    tfeverfred
    Pennzoil 10W-40. Never let ya down.
  4. Rich Rogers
    Rich Rogers
    Valvoline 10-40 in the daily( Dakota) and VR-1 Valvoline 20-50 in the 55 Chev
  5. Retro Jim
    Retro Jim
    Valvoline 10-40w in my daily driver and Royal Purple in my hot rods .
    RetroJim
  6. Tony
    Tony
    20-50 Valvoline race oil (VR-1) with (BG MOA or Comp Cams ***embly lube each time) in anything i own with a flat tappet cam. I used to use Shell Rotella, but i have read they changed the formula and removed some of the zink etc that it used to have...
    But i was of the understanding the Valvoline Race stuff still has it...
    Mobil 1 in my late model GMC with factory roller cam.
  7. Toddjg
    Toddjg
    from florida
    40 wt. napa
  8. flamedabone
    flamedabone
    Valvoline VR-1 Racing Oil NON-synthetic 20w-50. Specificaly formulated for flat tappet cams with high spring pressure.
    I never hurt a camshaft in my life untill about 2001 or so when I smoked four in a three year period. Why everyone was ****ing up cams in that time period is pretty well do***ented, but it comes down to sub-standard lifters and the reduction of zinc (and other hot rod friendly additives) in engine oil.
    Almost all non-synthetic,over the counter oils are great for old engines except for the reduced zinc content. Add a bottle of BLUE STP (look on the label, it says formulated with ZDDP, that is what you need) and you will be just fine.
    The whole synthetic vs non-synthetic argument is a whole 'nuther deal. Generally speaking, original old engines do not like synthetic oil due to anti-scuffing properties that effect ring seal on older engines.
    If you have an original 283 built in 1962, stay away from synthetic. If you have that same 283 built today with modern piston rings, ring tolerances and cyl wall hone synthetic is OK after a 1000 mile non-synthetic break in period.
    LOTS of good info in the search...it is a pretty hotly debated topic.
    Good luck, -Abone.
  9. Glen
    Glen
    Brad Penn 30wt.
  10. flamedabone
    flamedabone
    Yep, Brad-Penn is good ****, but can be hard to find and a bit pricey.
    -Abone.
  11. Glen
    Glen
    I should add a disclaimer for others......Please dont run out and buy 30 wt. oil for your old vintage motor....
    If your really bored and want to read about the zinc debate, there is a great conversation here. The main poster has been sending oil in for testing and getting results back disputing some of the makers claims.
    http://www.chevelles.com/forums/showthread.php?t=195620
  12. 29nash
    29nash
    from colorado
    5-30 in the winter, Nov to April, 20-50 in the summer. Lowest price available. Usually get it at Checker, when they have a sale it's a better buy than Walmart.
  13. pontiac
    pontiac
    I run straight 30w Valvoline in my 52 Flathead... 10W-30 Valvoline in my 64 Catalina.
  14. SCtattooer
    SCtattooer
    Mobil 1 in everything I own
  15. TORCO 10-40 with MPZ additive in all of drivers and Torco's Nitro blend 50 wt in the race car.
  16. chevy32
    chevy32
    have a 355 olds 11-1 roller engine
    switched to brad penn 20/50 a couple of years ago.
    inside of engine looks like a new nickel oil pressure hot or cold never changes. brad penn is
    the green oil that kendell co. used to make and brad penn
    bought the co.has all the good stuff in zinc etc. good old pa. oil:)
  17. Swifster
    Swifster
    Mobil 1 in my DD and I'll be using Brad Penn in the Studebaker.
  18. vernmotor
    vernmotor
    from ohio
    Rotela 15-40 in about everything..
  19. fearnoevo
    fearnoevo
    from Iowa
    Kendall GT-1 50W in the bikes, Quaker State 5W-30 in the cars, and Northland 70W in the fuel bike.
    Northland sponsors me, I only use 1 qt at a time and throw it away after each p*** anyways.
  20. DOUBLEZO
    DOUBLEZO
    from SACramento
    49 Ford with flathead, Rotella T 30 wt. Dailys, whatever is on sale.
  21. MarkzRodz
    MarkzRodz
    I've lost 3 or 4 cams in the last couple of years to the reduced levels of Zinc/Phosphates,etc. It's sad to hear of Rotella reducing the content.I've depended on it. What's happening to the diesel rigs on our highways,,how are they coping? Or our mowers and tillers,etc?
    When I broke in my newest 385 Stroker I used "Royal Purple Break-In Oil". I noticed that it smelled identical to rear end grease.The high pressure lubes must have that distinctive odor. Now after reasoning I add a little to all my engines to get the Zinc/Phos levels up. It's depressing how we're under attack everywhere we turn.
  22. Deyomatic
    Deyomatic
    from CT
    I've always wondered how to determine what weight your oil is supposed to be. Why would one recently built 350 engine need 20W-50 and another 10W-30?
  23. Candy-Man
    Candy-Man
    Diesel motor oil, 15 W 40, etc. has all the additives....
  24. Don's 55
    Don's 55
    I really like Castrol and used it in everything for as long as I can remember.
    But since the levels of zinc are way down, for my old cars I've been using Chevron Delo 400 and adding half a bottle of Lucas Breakin oil additive to kick up the zinc.
    I got a couple of thousand miles on the VooDoo Hydraulic Flat Tappet cam in my 383, so far so good. I did the breakin using a full bottle of Lucas with the Delo oil.
    I still use Castrol in my modern rides.
  25. Glen
    Glen
    Thats a great point. People brag about buying high dollar oil for their 2010 vehicle and at the same time say they purchased 10-40 or 20-50. Clueless.
  26. George
    George
    I saved up the older CI-4 diesel oil, it'lll last for a while. Wal-Mart sells Accel brand 10W-40 SF oil marked "for pre 88 cars" should have the zinc.
  27. dbradley
    dbradley
    5W30 Pennz Synthetic in everything............(all have roller cams)
  28. texoutsider
    texoutsider
    from Frisco, Tx
    Rotella in the Power Stroke ........everything else including the race cars use Mobil 1........15w50..........
    M.
  29. LowKat
    LowKat
    Texaco 30wt Aviation oil in metal cans.
    Bought 20 cases years ago at a garage sale for $10 a case,
    still have a few left
  30. fanspete
    fanspete
    Mobil 1 in the 'g***ers', Rotella T in the diesels.
    Looking at switching to Amsoil.(?)
    Funny how lots of guys put 'whatever' oil in the stuff they depend on every day!
    If I need it, it'll wait...if I want it, I gotta have it right now!
    We humans are an interesting animal!
