Hot Rods What oil should I be running in my flathead?
Discussion in 'The Hokey Ass Message Board' started by KustomCars, Nov 24, 2012.
  1. KustomCars
    KustomCars
    from Minnesota
    Is it okay to run 10w30 oil in my flathead or should I put straight 30?:confused:
    It is the original motor. Thanks
  2. 296 V8
    296 V8
    from Nor~Cal
    Some people say
    If its had non detergent to stay with it …. Allegedly detergent oil will loosen all the sludge.
  3. 64ONEOFF
    64ONEOFF
    from Md.
    I was told to use 15w 40w with zinc.....for diesels....The flathead guy in our neck of the woods Brad Wallace of Md. recommends it....literally told me 2 days ago.
  4. HUSSEY
    HUSSEY
    +1 on the Non detergent oil if its original.
    I'd go with a 10W oil so you get better oil flow when it's cold.
    I run Valvoline VR1 Racing Oil, I've learned that it has the proper amount of ZDDP additive. They quit putting in ZDDP because it poisons exhaust catalyst but it should be included to protect flat tappet cams.
  5. George
    George
    Try "search", a load of Threads exist.
  6. Thunderroad312
    Thunderroad312
    If the motor is original or has alot of miles, stick with a 30 or 40 weight, preferably a non-detergent.Stay away from multi-vicosity oils and really thin weights, in a well used motor.A bottle of Lucas oil wouldn't hurt either. High detergent oil will break loose sludge and cause all sorts of havoc.Now if the motor was rebuilt properly and all the clearances were in spec, you could run a thin, or multi-vis type oil and not hurt anything.JMO.Randy
  7. frosty49
    frosty49
    If the motor is not rebuilt use 30wt non detergent. If it is I use Mobil 1 20w50. Has the highest amount of zink.
  8. flatjack
    flatjack
    Detergent oil will not loosen sludge - old wives tale. Detergent oil holds impurities in suspension. Change oil on a regular basis.
  9. kennkat
    kennkat
    yes!!:):):):):):):):):):):):):):)
  10. kennkat
    kennkat
    Use "ZDDP Plus" for the needed zinc if you cannot find the proper diesel oil (being phased out, I was told).....
  11. kennkat
    kennkat
  12. 40FordGuy
    40FordGuy
    Ditto, flatjack.
    30 wt, and use what has the most zinc content.
    4TTRUK
  13. scrubba
    scrubba
    I use either Valvoline or N A P A 30 wht or 40 wht depending upon whats in stock . scrubba
  14. mohr hp
    mohr hp
    from Georgia
    Brad Penn. Lots of zinc. The enviro nazies stripped the zinc from Rotella.
  15. RICK R 44
    RICK R 44
    I use 15-40 diesel grade oil in my 8BA flathead. Now that muy son owns a Car-Quest, I use their brand.
  16. Landmule
    Landmule
    +1 for Brad Penn.
  17. hombres ruin
    hombres ruin
    i use brad penn 20-50 and its loaded with zinc,besides the guy that sells it is an alliance vendor
  18. LSGUN
    LSGUN
    from TX
    The wet kind.
  19. plym_46
    plym_46
    from central NY
    I have been using Tractor Supply Diesel oil 15w 40 since my engine was rebuilt. Runs 55 lbs at start up then 42 to 45 at cruise. Idles at 40.
  20. onekoolkat1950
    onekoolkat1950
    vr-50,with lucas stabilizer for mine.
  21. jrt49box
    jrt49box
    15w-40 rotella
  22. Shaun1162
    Shaun1162
    If an oil pan has been cleaned out, is it safe to run detergent oil? Not much sludge for it loosen up after that....
  23. hombres ruin
    hombres ruin
    you dont have to run detergent oil you can put some marvel mystery oil in before the change and it cleans up nice
  24. flatjack
    flatjack
    Yes. Don't believe that myth about loosening sludge.
  25. 343WINDOW
    343WINDOW
    What about synthetic ?????
  26. 343WINDOW
    343WINDOW
    I asked Mike Herman from H&H Flatheads and he said "Valveoline VR1 20-50w". I figure if anybody should know it would be these guys....
  27. Tommy's Cycle
    Tommy's Cycle
    from So Cal
  28. We usually run Val VR-1. Our flathead engine builder recommends it.
  29. KustomCars
    KustomCars
    from Minnesota
    Im sorry, totally forgot to say "thank you" to all of you guys!!
  30. yes....thanks y'all......
