What oil to use in a flathead?
Discussion in 'The Hokey Ass Message Board' started by FoMoCoPower, Oct 6, 2008.
  1. Garpo
    Garpo
    An old topic back to the top/////////////
    A couple of comments.
    90 weight is usually a gear oil. A similar viscosity to SAE50 engine oil.
    Oil companies measure engine and gear oils on a different scale. (Measurement in centistokes)
    Gear oils do not have additives for combustion residues.
    Cheaper oils usually have a lower additive mix. You get what you pay for.
    The choice of what is the 'right' oil for your motor is complicated. If you have a lot of $$ in your engine it is wise to look after it.
    Re additives, I was told a long time ago that adding additives was a bit like adding a s****ful of baking powder to Grandma's cake recipe. If the original recipe was lacking it will be improved. If correct, it will be made worse.
    A better idea is to combine the cost of the oil and additive and buy a better quality oil
    I feed my flathead a diet of 20/60 made specifically for cl***ic engines, with zinc etc. Oil is cheaper than parts.
  2. '29 Gizmo
    '29 Gizmo
    from UK
    Yep... it looks like oil technology has moved on since this thread started.
