What OT crap are you working on
Discussion in 'Off Topic Hot Rods & Customs' started by anthony myrick, May 9, 2024.
  1. gene-koning
    gene-koning
    That safety lever you tied down to make it run is attached to a kill switch that grounds out the power to the coil.
    I'm suspecting a bad wire between that switch and the coil. That wire may ground out if it swings to just the right place. Or maybe the switch itself, or the linkage between the lever and the switch is messed up.
    I'd start at the lever and inspect everything between it and where it cuts power to the coil.
    JohnLewis likes this.
  2. gene-koning
    gene-koning
    Its a 71 Duster? Doesn't all the wiring p*** through the bulkhead connector? Those are known to be corrosion collectors. Both gauges operate off ohm readings, and the wires for both gauges p*** separately through the bulkhead connector (the bulkhead connector uses male and female spade terminals all bundled together into blocks of male and female terminal ends for every wire that p***es through it). It wouldn't take much corrosion to cause a problem with either gauge wire as it p***es through the bulkhead connector. I would start by inspecting and cleaning the wire connections at the bulkhead connection.
    mrspeedyt, b-body-bob and JohnLewis like this.
  3. b-body-bob
    b-body-bob
    Only one of the wires p***es through the firewall, the fuel gauge runs down the kickpanel and under the interior to the trunk. I'll have a look at the bulkhead connector for the temp gauge; cleaning things never hurts.
  4. MAD MIKE
    MAD MIKE
    from 94577
    I knew I forgot to mention something...
    The safety brake/lever gizmo has always been a problem with this mower since new. It works, but it's a junk design and material wise. It has been modified to work predictably.
    Initially suspected that as a problem but it has been ruled out.
    One last hurrah of the old coil was to snip the grounding wire and let it run to failure, and did so as expect ~5 mins.
    New coil grounding wire was also kept disconnected and insulated to prevent unintended shutoff. Similar results, engine died after ~5mins.
    My current question is how does the gas tank vent?
    Only one fuel to carb outlet. And the gas cap is solid no venting.
    Does air enter back up through the fuel line?
    Maybe I'll do what all these flathead street rodders do, put some Amsoil 20W-50 in it :p
    I am thinking of an oil change just to see if it's getting glittery.
  5. lumpy 63
    lumpy 63
  6. gene-koning
    gene-koning
    So I've been thinking, does the carb float bowl have a wire attached to it? I had an old Craftsman garden tractor that had a wire attached to the bottom of the float bowl. That wire was attached to the "anti-backfire valve" inside the float bowl. Its entire purpose in life was to make sure the motor didn't backfire if it was shut off at higher rpm. Whenever the motor was running, there was electric power to the "valve" and when the motor was shut off, the power ended. The electric power held an elongated plunger inside of the float bowl up to allow fuel to flow into the float bowl. When the power was shut off, the plunger dropped and stopped the fuel from entering the float bowl, the carb essentially ran out of gas (pretty quickly I might add). On my mower, the anti-backfire valve would just loose the electric power coming in and the motor would quit running. Sometimes I could mow all day without issue, sometimes it would die with every lap. In my case, shortening the plunger solved the problem. The plunger had what looked like two heads on it, I cut the top head off, and that problem went away. I have no idea where the source of that electrical power came from, and didn't really care.
    porkshop likes this.
  7. SS327
    SS327
    What happens on the old B&S engines is the valves get all carboned up when the lash goes away and don’t fully seal. You got it fixed for now so just keep running it.
  8. Don West
    Don West
    nice save the rest of the body looks fairly decent
    mrspeedyt likes this.
  9. MAD MIKE
    MAD MIKE
    from 94577
    Nope, also I kinda goofed this carb is AL, was looking at the pressure washer which has the green plastic carb.
    This carb just has linkage that goes to an internal engine governor.
    I'm guessing it's similar to the 90's external govenors that was the flat lever blade which was controlled by the added 'fan' blowing on the lever to control throttle. It was hokey due to the fan/lever would easily be fouled by debris.
    Carb has a decent size bowl, fairly sure it's larger than a typical Q-Jet :D.
    After I file... adjusted valve lash, I did manually open the valves and let them smack closed a few times.
    Intake seemed OK but exhaust did seem to have a softer closing sound. Did spray inside the exhaust port with carb cleaner as I was thinking varnish gumminess.
    Valve started to make a proper smacking sound. Rechecked lash and it was still in spec, closed it up and let it run.
    Oil was a smidge low, topped off and let it run. These past two times it ran without *****. It did a single misfire but I had it hopping off a curb at an extreme angle.
    Fuel tank and Jerry tank were both drained and refilled with Chevrons finest Techron enhanced 87 Octane.
    Folks are getting up in age, wondering if they may have added something to the fuel. Mom is good for meddling like that:confused:. Still going to change oil, and hopefully this will the last I spend time editorializing about this contraption.
    chevy57dude and SS327 like this.
  10. chevy57dude
    chevy57dude
    enloe, lumpy 63 and porkshop like this.
  11. chevy57dude
    chevy57dude
    Finishing up the little stuff on the trailer my man Bill Squires sold me for an awesome price. After we settled on the deal, he bought 2 new tires and literally threw them in! At the tire shop today, while getting them mounted a call came on the intercom. Someone looking for a used trailer tire that size. I let Big Tony know that's what he's replacing for me. He looked at it and told the guy he had one. And this was the "worst" of the 4. Still usable for someone. Thanks Bill!
  12. lumpy 63
    lumpy 63
    enloe, porkshop, SS327 and 1 other person like this.
    erasing some letters
    enloe, porkshop and Okie Pete like this.
  14. lumpy 63
    lumpy 63
    20250816_110230.jpg 20250816_133626.jpg 20250816_134959.jpg Had a lot going on at shop today. Lots of friends stopped by, the camaro tear down continues.. installed the proper amount of pedals in it. Dwayne put some color on a big block 67
    Tickety Boo, enloe, porkshop and 9 others like this.
  15. chevy57dude
    chevy57dude
    The Chrysler/Dodge dealer relocated recently. The signs stayed, I've been eyeballing them. Friday a crew was removing them. Today I'm in town getting landscape supplies and I see the BIG sign in the dumpster getting cannibilized by some dude. Well, we helped each other and I came away with this. It's about 8 feet long.
    So the ot **** I'm working on is landscaping. But this is a by product.
    porkshop, lumpy 63, Okie Pete and 2 others like this.
  16. Okie Pete
    Okie Pete
    IMG_2541.jpeg Replacing the two bearings on this shaft that runs the the reel and header .
    Tickety Boo, enloe, porkshop and 4 others like this.
  17. lumpy 63
    lumpy 63
    20250818_182058.jpg Getting all the bits together for camaro engine
  18. JohnLewis
    JohnLewis
    Curious on what is on the warning tag.
  19. lumpy 63
    lumpy 63
  20. JohnLewis
    JohnLewis
    Just not use to seeing a warning tag anymore usually I get a single paper jammed in a box and it’s got 5 different languages on it lol
    porkshop, loudbang and lumpy 63 like this.
  21. swade41
    swade41
    from Buffalo,NY
    Cleaning up a little Japanese fm radio I found at the thrift store for $5 bucks, works great !
    20250819_134939.jpg 20250819_134930.jpg 20250819_134949.jpg 20250819_135008.jpg 20250819_135447.jpg
    enloe, mrspeedyt, porkshop and 7 others like this.
  22. Deuces
    Deuces
    Angle plug heads?????..... Are those 492s????.....:)
  23. T. Turtle
    T. Turtle
    No pics but between changing the valve stem seals on my 289 I helped a friend with his Audi RS4 B5. Took 1.5 hours to replace a front timing belt cover. Great cars when they work, but I would not want to do the maintenance on them. He tells me my 64 Comet was "too alive" for his taste. Oh well.
  24. lumpy 63
    lumpy 63
    those are NOS 292 turbo heads:cool:
    Tickety Boo, porkshop, Deuces and 2 others like this.
  25. jimmy six
    jimmy six
  26. Peezduk
    Peezduk
    removing the rust IMG_9501.JPG IMG_9547.JPG y tub
  27. JohnLewis
    JohnLewis
    Helping a buddy fix a Polaris, damn Fuji/Subaru motor. IMG_1627.jpeg IMG_1628.jpeg IMG_1629.jpeg IMG_1630.jpeg IMG_1631.jpeg
  28. JohnLewis
    JohnLewis
    IMG_1634.jpeg Might just be me, but I hate small engine work. I prefer to stick to the cars. This stuff ****s lol.
    porkshop, Okie Pete, Deuces and 3 others like this.
  29. Deuces
    Deuces
    I remember those.... Hotrod or Carcraft did a write up on those and also printed cut out templates for porting the intake and exhaust ports... I might still have that issue....:rolleyes:
    Tickety Boo, porkshop and SS327 like this.
  30. Deuces
    Deuces
