Projects What rear axle assembly?
Discussion in 'Traditional Hot Rods' started by usmc72, Jan 24, 2022.
  1. usmc72
    usmc72
    I have a 1940 Desoto that has a 55 291 going into it for power. Using the original transmission or a 727, haven't decided yet. The 55 trans has the shifter mounted on the dash with an e brake to park it. I need to hear what would you use as an 8 3/4 if I did not use the full drive train from the 55. The 40 has a rear end measuring 60 29/32 width. What would be close to this in B bodies? I will be converting to disc brakes for the Dallas Texas traffic. Using the 55 for nostalgia reasons.
  2. squirrel
  3. 73RR
    73RR
    Here is a link to some measurements that you can consider: Rear Axle | Quality Engineered Components
    The explore is readily available at the pik-n-pulls and often cheap, similar for the Cherokee.
    The only downside to the Mopar 8-3/4 is cost. I have some in the discount bin if you want to consider one.
  4. The newer rear will have a parking brake.
    Yours in currently on the trans, correct?
    If so, the 8 3/4 would solve one problem if ya change the trans.
    SS327 and squirrel like this.
