What rear axle for a 1946 Tudor.
Discussion in 'The Hokey Ass Message Board' started by John 79, Sep 20, 2010.
  1. John 79
    John 79
    from Sweden
    What kind of rear axle width fits under my 1946 Tudor.
    Going to put parallel leaf springs int he back.
    Somebody said that "older" Ford Bronco would fit and have the same bolt pattern as the 46.
    What did you use???
  2. klazurfer
    klazurfer
    Flathead V8 ? Souped up ? OHV V8 ? ... Custom ... G***er .. ?
    Klaz :)
  3. John 79
    John 79
    from Sweden
    Chevy S/B and trans.
    The rear axle have to be strong enough for 300hp.
  4. oldspert
    oldspert
    from Texas
  5. If you use anything from about 58 to 60 inches wide at the wheel mounting surfaces you will be good and not have clearance issues with your tires to the inner or outer fenders.(Using common sense with the offset)
    Granada,Camaro,Nova,some Mustangs,Early Bronco,Lincoln Versailles,all good donors. 8 inch or nine inch Ford and 10 or 12 bolt chevy-All good
    A mopar 8 3/4 would work also.
    A 58 inch wide rear will let you run 8 inch wide wheels with a fair amount of negative offset.
    Parallel springs ride good with these cars-just remember to use a sway bar front and rear.
    Posies and Ch***is Engineering kits both work good and are easy to install.
    Jim
  6. JimC
    JimC
    from W.C.,Mo.
    In my 47 I used Ch***is Engineering leafs, hangers, and shackles
    It was a bolt on, however, after alligning, it was welded in place.
    I went with a 68 Nova/Camaro rear. I did install a rear sway bar, new shocks, and put new bearings and seals in the rear (center and axles).
    I used a independent front with mid range Chevy rotors and calipers.
    If my car ever runs and drives, I can find parts literaly everywhere.
  7. Deuce Roadster
    Deuce Roadster
    IF you were in the United States :D I would suggest a 57/58/59 Ford p***enger car rear end. They are 58 inches wide ... measured from Wheel Mounting surface to wheel mounting surface ( NEVER use the backing plate to backing plate measurement ... offsets and brake drum widths will vary and mess you up BIG TIME :eek: ).
    They are of the 9 inch Ford family so parts and supplies are very plentiful here in the states. That said ... because you are in Sweden ... I would imagine your choices are fairly limited. The 57 to 72 F-100 rear is the same width as your original 46 Ford rear end ( at 60 inches WMS to WMS ) and are most likely more plentiful ( maybe ??? ) that the 57/58 59 Ford car rear end. Avoid the 73 up F-100 rear end as it is way too wide for a 46 Ford.
  8. millersgarage
    millersgarage
    I used the "older ford bronco" because it was the same width and bolt pattern........
    this was pre-hamb for me
  9. krylon32
    krylon32
    from Nebraska
    I've done several 46/48 ch***is using a CE rear leaf kit and the 9 inch rear out of a 60/64 Ford. Either p***enger car small brg or wagon big bearing. 61 inchs wide with 2.25 or 2.50 X 11 inch rear brakes.
  10. John 79
    John 79
    from Sweden
    Ive ordered a Posies paralell leaf spring kit and its for a 9 inch axle so thats what i have to get.
  11. kustomkatt
    kustomkatt
    from sweden
    Im doing the same swap in my 46 tudor and im using a 77 nova rearend , hung on pararell leafspring from a volvo 360, they are short enuff to fit just right, cheap and the ride is really good. Have two friends who have this setup..
  12. Gman0046
    Gman0046
    A chevy 10 bolt with Ch***is Engineering parallel leafs work great on my 46 Ford Convertible.
  13. John 79
    John 79
    from Sweden
    Bought a 1957 Mercury 9inch today,aboute one inch smaller than the 46 rearend.
