Projects What rear end?
Discussion in 'The Hokey Ass Message Board' started by IowaTom, Jul 23, 2024.
  1. IowaTom
    IowaTom
    Guys - I'm working on a friend's '52 Willys Aero to get back on the road. He told me a previous owner did a rear end swap and he thinks what's there now is an 8" Ford. Before I go to the parts store for new brake shoes & cylinders, I'd like to be sure.
    Also, can I pull the axle shafts as easily as my Dana rear ends? I'd like to grease up the bearings. 20240723_110019[1].jpg 20240723_110047[1].jpg
    This has 10 bolts, BTW. Thanks for your help!
  2. Illustrious Hector
    Illustrious Hector
    The easy way to tell is the bottom 2 nuts can be accessed straight on. On a 9 inch the pinion covers them
    and you need a wrench to loosen them. Bearings are lubed by the axle, 4 bolts each side, loosen the nuts on the backside of the backing plates.
    IowaTom likes this.
  3. jaracer
    jaracer
    It sure looks like an 8 inch, but could be a 9 inch; they are very similar. This rear end has sealed ball bearings on the axle, no way to grease them.
  4. squirrel
    that is an 8 inch.
    But that doesn't tell you what it's from, it could be anything from the early 60s to the late 70s or so?
    dana barlow and IowaTom like this.
  5. Happydaze
    Happydaze
    Not that you asked but those big lowering blocks and lowered shock mounts don't look like they're doing the scrub line any favours. I hope the wheels have large enough diameter.
    Chris
    IowaTom likes this.
  6. Weedburner 40
    Weedburner 40
    That is a Mustang 8", probably late 60's depending on width. The necked down housing is the giveaway.
    38Chevy454, warbird1, IowaTom and 2 others like this.
  7. I agree Mustang. Measure the drum diameter and shoe width. Another dimension to narrow it down is the axle register for the drum. 2-3/8" up to 72, 2-3/4" 73 up.
    IowaTom likes this.
  8. IowaTom
    IowaTom
    Thanks fellas! Very helpful!
  9. RICH B
    RICH B
    Wheel cylinder bore sizes vary too.
  10. 38Chevy454
    38Chevy454
    Just as many stated, that is a 60s 8-inch most likely out of a Mustang. The necked down tubes give that away, plus the rear housing appearance. The center section is 8-inch as well.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    The '74 mustang II 8" looks very much the same .
    squirrel likes this.
  12. squirrel
    it has 4 lug wheels
