What rear fits under a Model A
Discussion in 'The Hokey Ass Message Board' started by lrs30, Oct 7, 2009.
  1. lrs30
    lrs30
    from Kentucky
    What rear are you guys running under your FULL FENDERED MODEL A's??? And what did it come out of? I have my Suspension style figured out, now just need to find a Rear-end to fill that void..So tell me guys whatcha running... Ryan
  2. F&J
    F&J
    All depends on what wheel?
    old skinny steelies with very little backspacing
    deep dish mags or chrome reverse that stick out more
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Im running a Montego rear axle around the 74 year range.(at least thats what the tag numbers came up as).about the same as the Mavrick 8"- 56" 0r 56.5" WMF to WMF
    3.5" B.S. on the wheels.and running 235 75 R 15 rear tires on 7" AR Vintage TT wheelsout back and 4.5 wide up front with 185-80R 15's up front
    at this point the axles are not all the way in..this is at mock up..the wheels and tires do fit in tighter than in this picture im just now getting the rear end put all together.
    im going coil overs
    if you need any measurements PM me
  4. lrs30
    lrs30
    from Kentucky
    I am running Firestone Bias Ply 16 750 so the wheel I am looking for will be 40 ford style (aftermarket or what ever I can score) no wider than 5.5.. My hopes would be for a set of Torque Thrust D (grey center) and some redlines.. But I am gonna runn the steelies for now since I already have 2 and the tires...Sorry for the vague question...Ryan
  5. HotRodBen1987
    HotRodBen1987
    I'm running a 10 bolt gm rearend out of an 81 buick century with 15x6 steelies
  6. my `28 full fendered tudor has an 8" maverick that is about 56" wide wheel mounting flange to wheel mounting flange
  7. mj40's
    mj40's
    Maverick's work good under the narrow framed 28-34 Fords.
    LOU WELLS likes this.
  8. 31 roadster on 32 frame.
    Ford 9", measures 56" wheel flange to wheel flange w/drums.
    Wheels are 6" 15" with 235/75R x 15 tires.
    They fit well with either 29 or 31 fenders.
    31 fenders are 1" wider.
    Early roll-out with 10" x 15" slot mags(3" backspace) and 31.50 x 15 tires - 31" tall fwiw.
    These tires don't work with stock fenders.
    Directly from the back with the 6" wheels and 235 tires.
    The tires are hanging down cuz the car is up on jackstands.
    This is about as low as the rear can go.
    Car sits 1" higher now, rear suspension is set up so changes are easily made.
    I think this is a 31 fender.
    I bought a pair that were 29 and 31 already bobbed.
    The 29 fender on the drivers side fits the tire closely and looks good.
    The white fenders shown above are 31's and at 1" wider, more room for a bigger tire.
  9. FrozenMerc
    FrozenMerc
    I was running a Dana 44 out of a late 60's International Scout in my '29 2 door Sedan. Nice and narrow, fit well within the fenders, plus they come with factory posi and are virtually bullet proof. Unfortunately I don't have any pics.
    osage orange likes this.
  10. pasadenahotrod
    pasadenahotrod
    from Texas
    8" Ford rears from 64-68 Mustangs, 64-65 Falcon/Comet, 70s Maverick/Comet.
    10bolt GM from 68-74 Nova/Omega/etc.
  11. 53 Chevyply
    53 Chevyply
    OK... so I'll be the odd man out here.. My 30 coupe is running a 51 Pontiac rear diff with hairpins and coilovers. It was built that way when I got it and it seems fine. The car is running 14" rear tires, although I will be upgrading the rears to 15x10's asap.
  12. jakesbackyard
    jakesbackyard
    from ND
    The 8"ers out of 74-78 Mustang IIs, Pintos, Bobcats are the perfect width for A's with fenders. They have the 4 lug axles though, so the axles have to be redrilled to your pattern. I've used three of them that way.
  13. olskool34
    olskool34
    Bronco rear ends work well, I have a 68 and it retains the ford 5 on 5.5 bolt pattern. It is 57 hub to hub.
  14. lincolnolli
    lincolnolli
    from Germany
    65-66 Mustang 8" fits perfect.I sold a lot for A's.
    strong Ford rearend,5 lug,good breaks and tons of aftermarket support!
    67-up is mostly too wide,as this was a bigger,wider Mustang model!(except MustangII 4 lug)
    Ford 8.8 Explorer rearends fit too.Most are 3.73 posi which is great.From 92 oer something they even had disc brakes.But the pinion is a bit offset.But doable..
    Ollie
  15. BarryA
    BarryA
    Did you get many Volvo 144's/142's over there? Around 54" wide and pretty stout. Apparently LS versions were done but seem pretty scarce.
    Ford bolt pattern too. I have 2 waiting for projects....
    Barry
  16. lincolnolli
    lincolnolli
    from Germany
    Volvo,oh yeah.Made by dana.Most are posi!I've been told the turbo is the strongest.
    But i think thats more a solution for us,Barry.As we are not blessed with wrecking yards full of american cars..LOL..
    Ollie
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    were not blessed with them either..they all get melted down and sent over to china:mad::rolleyes:..finding a nice 8" or 9" rearend these days is getting more and more difficult as the years p***. especially the "one" you need
    that Volvo alternative sounds like a good start, a bit skinny but it would work.
  18. I'm have a 66 fairlane 8" with 2:73 gears and it works ok. brakes are 10" x 1 3/4"
  19. cheddar
    cheddar
    from missouri
    something easy to find, s-10 2wd 56" wms to wms.
  20. lincolnolli
    lincolnolli
    from Germany
    Yes,i heard about that fink.We are flooded with all the chinese **** too.And steel price go skyrocket!
    The chevy 7.5" is what i use too(Monza rear).They can be made very strong.I have 3.45s, a posi and bigger axles(more splines).Alle that cost not more than 300.-
    Ollie
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    shame these days picking around in junkyards over here in Michigan all we have to choose from are 1990's **** box front wheel drive cars..the old iron is slowly getting very hard to find..,, and with the s**** prices we had near the end of last year it really took alot of good parts and sent them to the melters
  22. lrs30
    lrs30
    from Kentucky
    I have a S-10 4x4 rear but I think it will be to wide, I have a line on a good S-10 2wd so I think I may go with it.. Unless I find a another that maybe stonger.... Thanks Guys keep em coming so I no what to look for in the yard on Saturday.. So staying somewhere in the 54 to 56 from drum face to drum face would be a good one to go with.. Is that the best way to measure?
  23. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Yep.
    and Yep..
    Thats how I measure anyways when it comes to fitting a rear into a project..if you know where your wheels are going to bolt up you can easily see what wheels and tire combos are going to fit, and what ones will look right and those that wont..JMO
  24. lrs30
    lrs30
    from Kentucky
    See thats where I am going about this in a different way... I am building a frame for an already complete car. I am putting the ch***is together first so i don't have to give up my running and driving car till the last minute.. So thats why I am asking what rear will work in advance..
  25. Warpspeed
    Warpspeed
    I guess you need to work backwards. Start with the measurement between the outer guard edges
    (anyone have that measurement for an A?)
    Then select the wheel and tire combination allowing for some guard clearance, maybe an inch on each side.
    Then measure the flange to flange measurement between the rims you would prefer to use.
    That should give you a ball park starting figure to aim for when junk yard crawling and research.
  26. Jessefelix
    Jessefelix
    from Hanford,Ca
    you could use a old jaguar rear end like a 60's to 70's, i am sure they are 56 inches from hub to hub and it has independant suspension.
  27. Warpspeed
    Warpspeed
    Yes that is correct. The Jag rears come in three widths, 53.25" 56" and 61.75" flange to flange.
  28. pompadour
    pompadour
  29. motoandy
    motoandy
    from MB, SC
    Soooooooooo, Not Traditional but it was free. Early Jag.
  30. lrs30
    lrs30
    from Kentucky
    Anybody else running a 2 wd S-10 Rear with success
