What rear fits under a Model A
Discussion in 'The Hokey Ass Message Board' started by lrs30, Oct 7, 2009.
  1. DE SOTO
    DE SOTO
    Don't sweat it Man, Sounds like NO ONE is useing Traditional Rear ends on the HAMB.
    I have an Open Drive Banjo that will be replaced by a '57 Olds rear in the Future... But i have NO FENDERS !
    Plan on a '40 Closed drive in my Fendered '31 Pick Up with a 347 Pontiac & '39 3spd
  2. lrs30
    lrs30
    from Kentucky
    I currently have a later 40's Closed drive but it is to wide for my fendered car.. I am still looking.....
  3. bobscogin
    bobscogin
    Speaking of Ford, the pre-'93 Ford Ranger rears are 56" wms to wms and available in 7.5" and 8.8" ring gears. Just picked one up for my '29A rpu. Perfect width.
    Bob
  4. lrs30
    lrs30
    from Kentucky
    Thanks for the info....What Bolt patern is the pre-93 ranger?
  5. bobscogin
    bobscogin
    The '90 model I got is a 4.5" X 5 pattern. It's out of a 2wd truck. Don't know about other years or the 4wd models.
    Bob
  6. My 89 Ranger is Ford, 4 1/2" x 5.
    If you get the rear axle from a 4x4 more than likely it'll have a locking diff.
    The brakes are - I think - 10" and fairly narrow.
    Even so, they do ok in the Ranger and it has disc brakes up front.
    Ratio is 3.74 if I remember right.
    (5-speed.)
    Not sure what the automatic ratio is, 3.54 rings a bell.
    The 4x4 rear axle is the 8.8"
  7. yngrodder
    yngrodder
    Early 70s ford Bronco Nine inch 5-5 1/2
  8. mikesplumbing
    mikesplumbing
    from Midwest
    My S-10 rear axel is 53 3/8" and that is measured from outside of drum hub to outside of drum hub.
    If you use the S-10 rear axel try and get the newer models from 1998 and up, if you do life becomes a little bit easier because the early S-10's use an unusual wheel cylinder mounting setup, while the later brakes use a standard 2-bolt mount.
    From what I have learned the the S-10 axel has a lot going for it because first off it's cheap as hell. Z-28's and Trans Ams came with basically the same set-up so you shouldn't worry about the strength. Gears are easy to get and other parts you can get at the local parts store for pretty cheap.
    Bolt patterns of course are the common 5 lug on 4 3/4" circle. If you find an S-10 blazer they are not the same, the measurement is close to 58"
    FYI-Most of the S-10's you find have 3.73 gears
    Hope that helps you in your search. The T-Bucket builders use a ton of these rear ends and they hold up great.
    Mike
  9. mikesplumbing
    mikesplumbing
    from Midwest
    Hey, I just checked craigs list in your state and there is a ton or S-10 rear ends for sale for cheap
    PS: My S-10 axel that is 54 3/8" is a 2wheel drive. If you want to go wider just use the 4 x 4 rear.
    Mike
  10. lrs30
    lrs30
    from Kentucky
    I have a 4x4 one already but I think it may be to wide, I have a line on a rear out of a MAVERICK for $200 I am gonna go check it out and see what shape it is in... I checked Craigslist last night and only found 2 and both where 4x4, I need to do another search, thanks for the info... Ryan
  11. Jim
    Jim
    I think that the one it comes with looks pretty good.....;)
  12. lrs30
    lrs30
    from Kentucky
    I do to but I don't think it will hold up to a SBC very long.. Unless you know of someone that can build it up for me to withstand a SBC for less than $an arm or a leg, I am gonna try a little more stout rear.. Trust me I would love to run a BANJO or a QUICKCHANGE but I am a average guy with an average income...lol Or better yet hook me up with a nice flatty....
  13. Marty Escarcega
    Marty Escarcega
    from Mesa, AZ
    How about a differential from a 1993 Fox Body Mustang it has the 302HO engine. I'm buying the donor car for the World Cl*** T5 transmission, driveshaft and differential to put in my 28A. It seems the rear end is 59-11/44" wide while the model A width is about 56". So thoughts on running as is or narrow it?
    Marty
  14. HOTRODPRIMER
    HOTRODPRIMER
    This thread is 9 years old, I'm pretty sure he has it figured out by now. HRP
  15. Chappy444
    Chappy444
  16. Marty Escarcega
    Marty Escarcega
    from Mesa, AZ
    Sorry, I'm a newbie BUT I am asking the question for myself....I am buying a 1993 Fox Body Mustang for its World Cl*** T5, driveshaft(to shorten of course) and the 8.8 differential. The rear end appears to be 3" wider than the A.
  17. when figuring out rear end width you need it depends on what size tires and wheels , and the wheel offset
    59" seams a bit wide for a fendered `28 model A, but if you will be using skinny tires who knows
    here is my `28 Tudor with a 56-1/2" wide Maverick rear end and 235/75R15 tires and 15 X 7 wheels, not sure of the offset 28tudor2.jpg
  18. Marty Escarcega
    Marty Escarcega
    from Mesa, AZ
    Thanks, I'm not opposed to having the axles narrowed. I am deciding whether to run open fender or keep the fenders/runing boards. If open, I can probably find a wheel offset that could take care of the 1-1/2" extra width....thinking out loud here with help from you guys! Nothing like ressurecting an OLD thread. Just shows I have poured through a lot of messages first. :)
  19. Blues4U
    Blues4U
    from So Cal
    Why would you go thru the extra costs of narrowing an axle when there are other axles out there that will work?
  20. Marty Escarcega
    Marty Escarcega
    from Mesa, AZ
    Just asking the question....I got the donor car pretty inexpesively
    I think its getting harder and harder to find the older axles. I used a Maverick rear end in the V8 Pinto I did way back when I was a teen...(I mean WAY back!)
  21. HOTRODPRIMER
    HOTRODPRIMER
    fiftyv8 and Blues4U like this.
  22. Marty Escarcega
    Marty Escarcega
    from Mesa, AZ
    Thank you for that link...the search begins...
