Technical What rear is this?
Discussion in 'Traditional Customs' started by Brandon141, Jun 12, 2024.
  1. Brandon141
    Brandon141
    IMG_2148.jpeg IMG_2149.jpeg IMG_2149.jpeg IMG_2148.jpeg What rear is this? Thanks.
    Sharpone and chryslerfan55 like this.
  2. Brandon141
    Brandon141
  3. squirrel
    probably 49-56 Ford car...
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The pinion is real low.
    Sharpone and JohnLewis like this.
  5. Brandon141
    Brandon141
    It is in my 55, but know if its original or not. Trying to buy rear gears for it.
  6. squirrel
    Well, that would explain why it's in there. Sure looks like the original rear end. I dont think anyone makes gears for them.
  7. @squirrel is correct (as usual), that is a 49-56 Ford "Hotchkiss design" rear axle. Parts are no longer made for it. If you are just trying to change ratio, used ones out of automatic models may be your best bet. There are very limited ratios that were made. If your rear is broken or bad, I would look for a later ***embly. An 8.8 Ford out of a Ranger or Explorer may work. An 8" out of an early Maverick is a bolt in with minor modifications.
  8. Brandon141
    Brandon141
    Well ****… will a 9” fit? What cars/ trucks do I look for to get the rear out of? Thanks.
  9. You will need something in the 57" WMS to WMS range. 57-59 Ford 9" is the same width, but good luck finding one. The 8" out of the Maverick is almost a bolt in. The spring pads have to be moved 3/4" on each side. Even your e-brake cables will work. A lot of gear choices too. The early 90s Ranger pick-up and late 90s Explorer is close to the same width, but the pinion is 2" off-center. GM intermediate cars in the 80s had a 10-bolt close to that width, research would be required.
  10. willys36
    willys36
    Sure looks similar to a '50-'60s Olds Pontiac. Back side 100% with that perfectly round dented cover but the ribs on the pumpkin aren't familiar.
    This is what another HAMB link says is a '49-'50 Ford.
  11. squirrel
    Ford used ****er rears in some wagons, and trucks and Tbirds in the 49-56 years.
    The Ford built 49-56 rear is about 2/3 the size of an Olds/Pontiac rear, which you can't really tell from the pictures.
  12. 1934coupe
    1934coupe
    Does it have a 5 on 5" BC if it does, 57-64 Olds/Pont.
    Pat
    Sharpone likes this.
  13. patsurf
    patsurf
    well -ONE thing can be told -one isn't a drop-out!
    ottersea and Sharpone like this.
  14. justpassinthru
    justpassinthru
  15. swifty
    swifty
    There was a 3.23 ratio available. Ford Australia carried that body style thru from 55 to 59 using grille and trim bits off Canadian models and the last year the automatic had a 3.23 rear. The Mainline (ute) had a 4.11 ratio but it was a different housing out of a Canadian Mercury. The 3.23 is very desirable out here and my son just swapped one into his 32 roadster instead of the 3.78.
  16. guthriesmith
    guthriesmith
    What gears does it have in it and what are you looking for? I have one out of a 55 sitting beside my shop that I don’t need…
    Sharpone and squirrel like this.
  17. I have seen the ratio in that rear 3.31 and 3.22 (automatics) and 3.89 and 4.10 (manuals). A 3.08 was in a reference once but I have never seen one. As stated, bearings, crush washer, pinion seal and some bearings can be found. A good used center section would be the easiest fix. Adding to my previous rear axle list, the 2004ish Mustang 8.8 is also about that width with a centered pinion but will have disc brakes.
  18. orangedog
    orangedog
    Looks like the one in my 54, mine has 3.54 gears. I recently replaced all the bearings and seals in mine. The ring gear is 8 in.
  19. gimpyshotrods
    gimpyshotrods
    Square body Ranger Pickup 7.5 and 8.8 rears are 56-1/2" wide, are plentiful in yards, still have parts available, and have a half-dozen ratios to choose from, often with a clutch style limited slip differential.
    Sharpone and Bangingoldtin like this.
