what`s this tool do ?
Discussion in 'The Hokey Ass Message Board' started by Casey, Mar 23, 2008.
  1. Casey
    Casey
    <DD>DRILL PRESS: A tall upright machine useful for suddenly ******ing flat </DD>
    <DD>metal bar stock out of your hands so that it smacks you in the chest and
    <DD>flings your soda across the room, splattering it against that freshly-stained
    <DD>heirloom piece you were drying.
    <DD>WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
    <DD>the workbench with the speed of light. Also removes fingerprints and
    <DD>hard-earned guitar callouses from fingers in about the time it takes you to say,
    <DD>'Yeouw....'
    <DD>ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
    <DD>holes until you die of old age, or for perforating something behind and beyond
    <DD>the original intended target objec t.
    <DD>SKIL SAW: A portable cutting tool used to make studs too short.
    <DD>PLIERS: Used to round off bolt heads. Sometimes used in the creation of
    <DD>blood-blisters.
    <DD>BELT SANDER: An electric sanding tool commonly used to convert minor
    <DD>touch-up jobs into major refinishing jobs. Caution: Avoid using for manicures.
    <DD>HACKSAW: One of a family of cutting tools built for frustration enhancement.
    <DD>It transforms human energy into a crooked, unpredictable motion, and the
    <DD>more you attempt to influence its course, the more dismal your
    <DD>future becomes.
    <DD>VISE-GRIPS: Generally used after pliers to completely round off bolt
    <DD>heads. If nothing else is available, they can also be used to transfer
    <DD>intense welding heat to the palm of your hand.
    <DD>WELDING GLOVES: Heavy duty leather gloves used to prolong the
    <DD>conduction of intense welding heat to the palm of your hand.
    <DD>OXYACETYLENE TORCH: Used almost entirely for lighting various flam mable
    <DD>objects in your shop on fire. Also handy for igniting the grease inside
    <DD>the wheel hub you want the bearing race out of.
    <DD>WHITWORTH SOCKETS: Once used for working on older British cars and
    <DD>motorcycles, they are now used mainly for impersonating that 9/16 or
    <DD>1/2 socket you've been searching for the last 45 minutes.
    <DD>TABLE SAW: A large stationary power tool commonly used to launch wood
    <DD>projectiles for testing wall integrity.
    <DD>HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
    <DD>after you have installed your new brake shoes, trapping the jack handle
    <DD>firmly under the bumper.
    <DD>EIGHT-FOOT LONG YELLOW PINE 4X4: Used for levering an automobile upward
    <DD>off of a trapped hydraulic jack handle.
    <DD>TWEEZERS: A tool for removing wood splinters and wire wheel wires.
    <DD>E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
    <DD>drill bit that snaps neatly off in bolt holes thereby ending any p ossible future use.
    <DD>RADIAL ARM SAW: A large stationary power saw primarily used by most
    <DD>shops to scare neophytes into choosing another line of work.
    <DD>TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength
    <DD>of everything you forgot to disconnect.
    <DD>CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
    <DD>inexplicably has an accurately machined screwdriver tip on the end opposite the
    <DD>handle.
    <DD>AVIATION METAL SNIPS: See hacksaw.
    <DD>TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called
    <DD>a drop light, it is a good source of vitamin D, 'the sunshine vitamin,'
    <DD>which is not otherwise found under cars at night. Health benefits aside, its
    <DD>main purpose is to consume 40- watt light bulbs at about the same rate that
    <DD>105mm howitzer shells might be used during, say, the first few hours of the
    <DD>Battle of the Bulge. More often dark than light, its name is somewhat
    <DD>misleading. The accessory soc ket within the base, has been permanently rendered
    <DD>useless, unless requiring a source of 117vac power to shock the mechanic
    <DD>senseless.
    <DD>PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under
    <DD>lids, opening old-style paper-and-tin oil cans and splashing oil on your
    <DD>shirt; but can also be used, as the name implies, to strip out Phillips screw
    <DD>heads.
    <DD>STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
    <DD>convert common slotted screws into non-removable screws.
    <DD>AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
    <DD>power plant 200 miles away and transforms it into compressed air that travels
    <DD>by hose to a Chicago Pneumatic impact gun that grips rusty bolts which
    <DD>were last over tightened 40 years ago by someone at VW, and instantly rounds
    <DD>off their heads. Also used to quickly snap off lug nuts.
    <DD>PRY BAR: A tool used to crumple the metal surrounding that clip or
    <DD>bracket you needed to remove in order to replace a 50 cent part.
    <DD>HOSE CUTTER: A tool used to make hoses too short.
    <DD>HAMMER: Originally employed as a weapon of war, the hammer nowadays is
    <DD>used as a kind of divining rod to locate the most expensive parts adjacent to
    <DD>the object we are trying to hit.
    <DD>MECHANIC'S KNIFE: Used to open and slice through the contents of
    <DD>cardboard cartons delivered to your front door; works particularly well on
    <DD>contents such as seats, vinyl records, liquids in plastic bottles, collector
    <DD>magazines, refund checks, and rubber or plastic parts. Especially
    <DD>useful for slicing work clothes, but only while in use. It is also useful for
    <DD>removing large chunks of human flesh from the user's hands.
    <DD>DAMMIT TOOL: (I have lot's of these) Any handy tool that you grab and
    <DD>throw across the garage while yelling 'DAMMIT' at the top of your lungs. It
    <DD>is also, most often, the next tool that you will need after a really big hammer
    <DD>_________________
    </DD>
  2. HAHA thats awesome! It's funny 'cause it's true :(
    -Dean
  3. seatex
    seatex
    I'm pretty sure that all of my tools have been "dammit" tools at one time or another......................... I was wondering what they were called! :):):)
  4. SlowandLow63
    SlowandLow63
    from Central NJ
    Great, funniest thing I've heard all day!
  5. Noland
    Noland
    very creative
    dont forget the METRIC tools good for ****ing up good American bolts
    and DRAIN PANS they must have some protective dome over them to prevent any liquids from being cought in them while spilling substances on to the ground.
  6. zman
    zman
    from Garner, NC
    this is probably the 20th time this has been posted on here, it gets less amusing as time goes on...
  7. lostforawhile
    lostforawhile
  8. MN Falcon
    MN Falcon
  9. Tetanus
    Tetanus
    I think i pissed myself....Thats funny ****!!!
  10. SHOE-BOX-JOE
    SHOE-BOX-JOE
    ahh man i thank you very much. i needed a great laugh after a frustrating day with my small block an oil leak and my dumb *** breaking stuff and making lakes of oil that me and my dog enjoyed sliding around my garage trying to clean up.
  11. Irrational Metalworks
    Alliance Vendor
    from DFW
  12. BOBBY FORD
    BOBBY FORD
    Glad it was posted. Funny as hell. Some of us haven't been on here forever!
  13. Lugnut II
    Lugnut II
    Funny as hell!!!:D I always felt your creative side would come to light as soon as you let go of your Buzzard thing.:cool:
  14. senior fried
    senior fried
    What are you doing ,trying to fire em up again !
  15. Thorkle Rod
    Thorkle Rod
  16. buzzard
    buzzard
    Alliance Member
    Still fired up over here. **** you's and name calling will do that.
  17. Lugnut II
    Lugnut II
    Hell No!!! I think it would be kinda cool if Casey and Buzzard would just smoke a PEACE PIPE and lets get on to more productive things!
