Customs What should i do to my hood???
Discussion in 'The Hokey Ass Message Board' started by tankwilson, Jun 15, 2010.
  1. tankwilson
    tankwilson
    Hey guys and gals been thinking about what other mods i want to do to the ol plymouth. Since the pics i have removed the gravel guards, rocker trim, and lowered it more. Not really into skirts and frenched headlights but would like to do some other tradional modifications. I am planning on putting belt line trim back on similar to a merc. Since the chop i have never really like the way my hood looks. Ran without a hood for a bit and loved it, but would really like to change it someway. Look at the bottom pic to get a good side profile.
    Any suggestions???
    Thanks
    matt
  2. plodge55aqua
    plodge55aqua
    from Alberta
    it looks really good the way it is... put a (S) Scoop on each side..
  3. Tank, I know this could be a major job but what if you follow the same upper line as the top of the fender, to get rid of the pointiness of the front of the hood. Probably would balance the curviness of the roof profile . My 2 cents , Rob
  4. Master of None
    Master of None
    You could pancake it and take wedge slit out of it to take some of the peak out. Like 2in in the front and taper to the rear.It will lay the hood down just slightly.
  5. big creep
    big creep
    round the corners?
  6. tankwilson
    tankwilson
    Yea thought about pancaking it but not sure where to make the cuts and how to line it back up. Any thoughts. Not sure on the the rounded corners.... will have to think about it. Seems like a lot of work for not alot of change.
  7. resqd37Zep
    resqd37Zep
    from Nor Cal
    Yeah all of the above. Especially the pancake. That will elimanite the buldge in the front of the hood and inprove the overall profile of the car.
  8. Antny
    Antny
    from Noo Yawk
    I agree. It looks great as-is.
  9. BloodyKnuckles
    BloodyKnuckles
    Tank,
    It's funny, I'm trying to change mine also but I want mine like yours. I'm planning on a '50 Ford hood.
    Personally, I wouldn't change it. Maybe a change in headlights but other than that I really like your car.
    How are you diggin' the discs?
    ******Knuckles
  10. Deuces
    Deuces
  11. tankwilson
    tankwilson
    It is painted.
    Disc brakes and dual master cylinder and new lines are one less thing to worrry about now. Yea really like them. I set it up just like ECI told me to do and i think if i take out the hold off vavle up front it would stop quicker.
  12. nutajunka
    nutajunka
    Peak the center from front to mid-back, then it would'nt look so round.
  13. DrJ
    DrJ
    Unless you mold in a grill opening don't radius the corners.
    It would be mixed messages.
    don't pie cut pancake or any of that "'90's custom rod" ****.
    You do need perfect alignment though. I think the right fender needs to come up some at the front to meet the hood. and carry on from there.
    Paint it when it's all straight.
  14. Russian
    Russian
    How about this?
  15. Mudslinger
    Mudslinger
    Put a peek on the nose and fade it back.
  16. tankwilson
    tankwilson
    Looks better but how do I do that in metal???
  17. krackerjack88
    krackerjack88
    from Fresno,Ca
    Change the grille
  18. Pilot01
    Pilot01
  19. GaryB
    GaryB
    from Reno,nv
    how about some louvers
  20. BuiltFerComfort
    BuiltFerComfort
    Check out pictures of a "sharknose Graham" and then compare it to your pics - adding a little to the nose might be an idea? Try a photoshop first of course.
  21. Shagrat
    Shagrat
    51-54 Chrysler/Desoto hoods flow better, not the bull nose look of the Plymouth/Dodge. I've got one from a 54 Imperial you can have if you want it. It would need a little slicing and dicing to make it work, but it's a thought...
  22. claymore
    claymore
    Get in some bodywork practice bumping out all the dents before moving on to the special stuff.
  23. gnichols
    gnichols
    from Tampa, FL
    I think it's great as is. Put some color on it. Gary
  24. cheveey57
    cheveey57
    first thing is, put the gravel guards back on, they are the first thing that popped in the first pic. I said to myself how cool that car was.
    My2Sense
  25. spooler41
    spooler41
    Man this is to easy, take it off and turn it over, wait for "SNOW". Just kidding, could'nt resist that one.
    ..........JACK
  26. ARVCo.
    ARVCo.
    Tank, first off your car looks great!! If you did want to modify the hood you could try louver. If you leave the hood alone, maybe redoing the grille adding vertical elements, close together, and/or possibly frenching the lights. Seriously though, I would leave her as she is right now.
  27. oldcarfan
    oldcarfan
    from missouri
    i think dueces ment real paint.
  28. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    louvers would look KILLER on that car.
  29. rjgideon
    rjgideon
    The 49-50 Plymouths have a lot of peak to the front of the hood. 51-52 has less of a peak, that '54 Imperial hood would really smooth things out, but would be a lot of metal work. How high does your core support and radiator sit inside your hood? I doubt there's much room for a lower-profile hood.
  30. Tin Can
    Tin Can
    I second or third or 4th the louver idea, the car looks good as is. Throw some color on it and it will totally change the look of the car
