What should I offer on a Nailhead from a '58 Super?
Discussion in 'The Hokey Ass Message Board' started by BOP-Nut, Feb 28, 2009.
  1. BOP-Nut
    BOP-Nut
    Found one in a junkyard this morning, don't want to low ball the guy. Engine only.
    It's my dream motor and I can't believe I found one 5 miles away.
  2. Dakota
    Dakota
    from Beulah, ND
    that would be a 364... kinda the oddball.
    good engine, hard to find correct intakes, although 322 inakes and log style ones will work,
    does it run? big factor.
  3. zman
    zman
    from Garner, NC
    322 intakes will not work, yes you can elongate the holes to bolt it on but the ports are way off and most intakes don't have enough meat to fix it. Log intakes fit any Nailhead. The Offy stuff is still being made for the 364's, not great but better than a 2 barrel. The stock 4 barrel intakes are ok. Same bellhousing pattern as the 401/425 which is good. Probably can't find out if it runs, but if it turns and seems to have compression $200-300 for a 364. If you can hear it run $500. If it doesn't turn I wouldn't even bother.
  4. BOP-Nut
    BOP-Nut
    Thank you for the input. So the 364 is not a good investment then? I can't find a 322 anywhere near me.
    The guy says it ran before it was parked there a few years ago, but that's what everyone always says.
  5. aplayer
    aplayer
    I say buy it. I paid $700 for a '61 LeSabre just to get the 364. I parted out the car and ended up making a little money. I bought the Offy manifold; I know it doesn't flow as well as some, but for the type of driving I'll be doing I don't think it will matter. And there's plenty of shiny stuff that will bolt to the 364.
  6. Stock 4bbl intakes can be had for $100-$150 or so.
  7. Dakota
    Dakota
    from Beulah, ND
    the 364 is a decent motor, my dad has one thats balanced, 12.5 : 1 pistons, solid isky cam, and an aluminum flywheel, we even found a early weiand dual quad intake for it.
