What size clutch for a T5 Behind a Y Block
Discussion in 'The Hokey Ass Message Board' started by oldspwr, Jan 2, 2014.
  1. oldspwr
    oldspwr
    For my 26T project, I am running a 272 Y block with a T5. To adapt the trans, I have an NOS Offy Y block to flathead trans adapter along with a new Offy flathead to T5 adapter from Speedway.
    The new adapter uses the original Ford clutch linkage. So my question is what size clutch should I use, 9", 10" or 11"?
    I may upgrade to a 312 someday if that means anything...
    Here is a quick pic...
  2. I put the biggest I could in my "56 P.U. Works great!
    Fenderless
  3. rob lee
    rob lee
    from omaha,ne
    Late 80s astro van clutch,11in should do the trick.
  4. seb fontana
    seb fontana
    from ct
    What spline is the trans? Sometimes that makes a problem..
  5. oldspwr
    oldspwr
    The T5 came from a very early 93 S10 and it has 14 splines. My real question is what is the right diameter clutch to run?
  6. Jimmy2car
    Jimmy2car
    from No. Cal
  7. rob lee
    rob lee
    from omaha,ne
    Use whatever size fits your pressure plate the best,14 spline common to s10.Ford pressure plate I assume?
