What size drill bit for 5/16" tap?
Discussion in 'The Hokey Ass Message Board' started by 36tudordeluxe, Aug 23, 2013.
  1. 36tudordeluxe
    36tudordeluxe
    Want to tap repo. '40 steering wheel hub so I can use my steering wheel puller. Puller bolts are 5/16," what size tap do I use?
  2. willys1
    willys1
    from South Ga
    17/64 drill for 5/16-18 threads
  3. 36tudordeluxe
    36tudordeluxe
    Thank you!
  4. DS1937
    DS1937
    Letter Drills
    5/16-18=Letter F
    5/16-24=Letter I
  5. Larry T
    Larry T
  6. Als27T
    Als27T
    Here's an opportunity to print a reference on tap drill sizes.
  7. Dan Timberlake
    Dan Timberlake
    If the tapped hole engages 2 full diameters of the bolt/screw, the tap drill size can be enlarged a little bit and decrease the "probable % of thread" and still maintain 100% of the fastener strength. That can be handy when tapping tricky materials or scary deep holes with smallish thread sizes.
    I think Machinery Handbook has a few extra columns in their tap drill charts for reduce probable % of threads.
  8. CR1193
    CR1193
    from Tennessee
    X2, ....will def. reduce the oh **** factor :D
    you should be good with an "f" drill, .257" dia. & it will probably run out a few thousands also, up around .259-60"
  9. tfeverfred
    tfeverfred
    There's one in the back pages of a book I needed for my welding cl***es. Came in handy a few times.
  10. sport fury
    sport fury
    you can always google drill tap chart
  11. BobMcD
    BobMcD
    Many times the drill size is marked right on the tap. Old repair manuals usually have a chart in the back for reference.
  12. sport fury
    sport fury
    in general different metals require specific tap clearances. aluminum should be drilled tapped with lubricant for aluminum to prevent galling. turn tap a 1/4 turn at a time then reverse about a 1/2 turn. it is very easy to break a tap off in aluminum even though it is soft than steel. chamfer the drilled hole so as not to create a paper thin thread at the top of the hole. there are also chamfer charts for this. get a machinists handbook. it can be a great help when working with metals. use a drill block to keep drill and tap straight in hole.
  13. Roger Walling
    Roger Walling
    In what I thought was a very simple question with a simple answer turned out to be a thread with a lot of interesting facts.
    Thanks to all for the info.
  14. Good rule of thumb. Hold drill in front of tap and be able to see the threads of the tap and not the shank. Also works for metal screws etc.
  15. Mr48chev
    Yes for the most part it is. I just went though hunting down the right drill bit size for a tap last weekend. The drill bit/tap charts are invaluable to have in your shop info binder.
  16. gatz
    gatz
    did you know......
    the tap-drill size for metric bolts is..
    the major diameter less the pitch, (both in millimeters)
    for instance; M8x1.0 , tap drill is 7mm
    M24x3.0, tap drill is 21.0mm
    of course, most people don't have metric drills (me included), so a close English equivalent would work.
  17. blowby
    blowby
    from Nicasio Ca
    Yep, glad I didn't post some snappy answer like "look it up dummy".
