What steering box do I have
Discussion in 'The Hokey Ass Message Board' started by jjjmm56, Feb 10, 2015.
  1. jjjmm56
    jjjmm56
    from FL.
    What box is this and were can I find a longer straight pitman arm ImageUploadedByH.A.M.B.1423614295.214242.jpg ImageUploadedByH.A.M.B.1423614417.480466.jpg ImageUploadedByH.A.M.B.1423614436.365191.jpg
  2. ken1939
    ken1939
  3. dave lewis
    dave lewis
    from Nampa ID
    Gotta be careful here..
    Longer. .straight steering arm with the correct spline for that box is.....
    71 camaro z-28 manual steering. .
  4. jjjmm56
    jjjmm56
    from FL.
    Is this a box I want to keep or switch to vega, for my 36 ford pickup?
  5. Marty Strode
    Marty Strode
    How many turns lock to lock ? I am using the same box in my 40 pickup, mine is 4 turns. Ch***is Engineering sells a plate that will bolt it right in. I would use it over a Vega, if it's in good condition.
  6. jjjmm56
    jjjmm56
    from FL.
    The PO made a bracket to mount to frame. Problem I have is pitman arm is not long enough. Found a universal arm in speedway for a repo box,I'll call in the am to see if it will fit
  7. It's identical to the steering box in my truck, which came out of a '64 Chevelle. The splines are the same as a '37-'48 Ford pitman arm. I have the original Ford pitman arm on the Saginaw box in my truck.
  8. jjjmm56
    jjjmm56
    from FL.
    This box is 6 1/4 turns lock to lock
  9. Rcraft
    Rcraft
    from cypress tx
    JEEP SAGINAW 535
  10. 31Apickup
    31Apickup
    Its a Saginaw 525 box, uses the same mount as a Vega box.
  11. jjjmm56
    jjjmm56
    from FL.
    Is this a good box to use, ill end up buying a pitman arm and rebuild kit for it so, is it worth spending money on it or getting something that might be better. Thanks for all the help
